Question about Kenmore Sewing Machines
How do you oil Sears sewing machine 385.16020100?
The manual does not present a picture that matches the interior of the machine. It is not clear where a sewer should oil the machine
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
  • 15 Answers
SOURCE: how to oil my sewing machine
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Posted on Nov 20, 2008
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
  • 108 Answers
SOURCE: Please advise where to get a free manual for sears
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
Singer sewing machine model # 158.523 manuals
Sears has manuals for most of their products, including sewing machines. Probably not free, but the price would be justified to learn how to use and maintain the machine, ie cleaning and oiling.
Jan 06, 2017 | Singer Sewing Machines
Looking for a users manual for a Sears Kenmore sewing machine model 158.120, not a parts manual.
I would first try Google and ask for service manual for your model. A close model match may do the trick as usually very little variation in same model series. Also, if you locate a Sears service center nearby, they may be able to help you find or instruct you in what you need . Good hunting
Jan 03, 2017 | Kenmore Sewing Machines
How do I oil a Kenmore 385 sewing machine
Are these the pictures you have?
KENMORE 385 12612090 Owner Manual Oiling The Machine Oil The Underside
Something you can do is slightly wiggle the handwheel (do not turn it in reverse). The handwheel should always turn toward you.
Look at the pictures and watch where metal rubs on metal that might match the picture and apply one drop of fresh, good quality sewing machine oil.
Aug 04, 2016 | Kenmore Sewing Machines
Why is hand wheel stuck?
If it is a mechanical sewing machine (pre-1990), it most likely needs cleaning and oiling. (Old oil has turned to goo and is sticking things.) Consult your manual. Use good quality sewing machine oil (NOT 3-in-1, WD-40, cooking oil, or your grandmother's sewing machine oil). Apply only 1-2 drops each spot as instructed. Concentrate on the area around the handwheel since that's where your problem is, but the entire machine should be oiled. You can direct hot air from a handheld hairdryer into the interior mechanics to help loosen things. Let cool and test. Wiggle the handwheel and see if things have changed. Repeat oil/heat until your machine is working again. In the future, be sure to clean and oil every 8-10 hours of constant sewing or at least every six months if not in use.
Or take it for service to a good sewing machine repair service.
Aug 10, 2015 | Sewing Machines
Is there a manual for the portable Kenmore sewing machine 158-12292? Is one supposed to oil this machine?
There are few parts to oil in any sewing machine, but if you must, be sure to use a clear, light machine oil such as "3 in 1" oil, etc. The manuals are here: http://www.kenmoresewingmanuals.com/kenmore_158_manuals/kenmore_158_manuals.htm
Jan 08, 2015 | Kenmore Sewing Machines
Where are the oiling points on this model??
Ok, googled "sewing machine 385 12914" and it brought up Kenmore.... you can get most of their manuals through the sears website. But I did not find 385 12914.... here is a 385. 12714 set of manuals on this page including a service manual. Perhaps they are close to your model?
http://www.searspartsdirect.com/partsdirect/user-manuals/38512714090-Kenmore-SEWING+MACHINE-manual
Aug 31, 2012 | Sewing Machines
Need to oil singer 7422 , where do I put the oil
The Instruction Manual for the Singer 7422 is available here:
http://download.sears.com/own/02018030s.pdf
Refer to the section on Caring for Your Machine beginning on page 63 of the PDF; illustrated instructions are provided for oiling.
Nov 03, 2010 | Singer 7442 Mechanical Sewing Machine
Looking for the manual for the Kenmore sewing machine model 158.1320
here you go you will need your serial number to match to the specific manual but im putting you in the right direction.
kenmore Manuals
Mar 25, 2010 | Kenmore Sewing Machines
Sears model 13 kenmore won't sew forward
its not easy sewing left handed is it? i think that oil has got into the switch and you have lost forwards drive now,,give it a good wiggel about till it clears it out, if it was working ok the last time you used it its just got a bit sticky thats all,,,i hope you used a light oil?
Oct 24, 2009 | Kenmore 12102
Sewing Machines Logo
32 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
