Question about Pyle AMFM CD DET MARINE RADIO R/C
Plye screen player won't appear - Pyle AMFM CD DET MARINE RADIO R/C
How can I fix the cd tray on a plye PTTCSM60 stereo?
I would use an optical disc player cleaner, you know, the one that looks like a CD? Then I would check the CD for damage and dirt. Clean it with a VERY soft cloth, being careful not to scratch it. If the CD is damaged, you might try another CD.
Apr 27, 2014 | Pyle Home PTTCSM60 Turntable Boombox With...
CD player appears to be dead but CD won't stop spinning
When a CD player goes south, it is almost always a given that the easiest and cheapest solution is a newer, higher-quality model. Just replace it. . .
Jul 26, 2017 | Sony Walkman D-SJ301 Personal CD Player
DVD won't play
The DVD player appears to have more than one problem, I recommend it be replaced "far cheaper"
Mar 18, 2012 | Audiovox Televison & Video
Install flash player but not plye youtoub ( samsung gt-b3410 mobile ) and show massage display eroo plesh securti satting and plz your mobile nomber
Phones doen't plays youtube videos as they r usualy in.flv fromat...So you should covert them into your Phones supprted format i.e .mp4 or .mpeg etc then transfer them to phone they will run......
Apr 03, 2011 | Samsung B3410 Cell Phone
How to bypass the plye tv deck to play while driving
you need a 2 way toggle switch, then solder ground to one side, and find brake wire from radio harness and solder that to the other side of toggle switch, then flip the switch to on and your ready to watch and drive, disconnected harness from radio first
Feb 20, 2010 | Jensen VM9510 Car DVD Player
WHY NOT PLYE MP3
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Sep 27, 2009 | Apple iPod nano
Pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Feb 05, 2009 | Pyle Car Audio & Video
All settings for my plye dvd player restarts anytime i turn the ignition on.
Check if the stereo direct positive lead is right connected.Good luck
Sep 18, 2008 | Pyle Car Audio & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Pyle AMFM CD DET MARINE RADIO R/C Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
