Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Is anyone from Canada wiht the F1 problem on their Cabrio washer?? I called the 800 number and they are insisting that it's different becuase these cases are not from Canada - My instinct is that this is a load of ****! If anyone is calling a Canadian # would you mind listing it. Thanks :)
  • Joe Povoas May 11, 2010
    flashes first F and then 1
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%#
Posted on Sep 20, 2010
I am alway getting the f1 code
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall!
Nov 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When I start the washer the dial flashes and says F1
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does F1 code show and the washer stop on my whirlpool cabrio
Thank you !!
Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer cabrio whirlpool do not rinse after wash theres a code F1
Hi, just to let you know - I called 1-800-253-1301 and explained that this is regarding the infamous Cabrio - F1 problem that hundreds of people have complained about all over the internet and apparently is a common problem. The lady (KIM) acknowledged that Whirlpool is having this issue and she immediately scheduled a Service Tech appointment for tomorrow. She confirmed that the service call and any part will be picked up by Whirlpool.
Take care
Jun 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
States F1 everytime going to wash
Call Whirlpool Customer Service at 800-253-1301
tell them you have a F1 code appearing repeatedly,and that you are aware of a "rework" issue regarding the control board, and that you want a service call to be set-up, This is a VERY common problem with this machine, along with the F-51 code which is a bad RPS. The control board will need to be replaced.
www.appliancehelponline.com
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
I keep getting f1 code on my cabrio washer
by recommendation from this site, I called Whirlpool and was ready to do battle since my Cabrio washer was well out of warranty. As soon as I described the F1 code a very pleasant agent immediately admitted it was a quality issue and offered immediately to set up a time for a repair free of charge. 2 days later my washer was fixed. Great experience.
Jul 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
Cabrio Whirlpool WTW6600SWO
you have a cabrio not a calypso..1st calypso did not display f1 codes BUT a cabrio does indicating bad control module.. changed 1 last week same issue..i'm sure if you go to sears .com click parts link type in your model number it will come up a cabrio..let me know how it turns out
Nov 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
