Question about Saws
List of porcelain marks14r09r90 - Saws
The grill grates have to be replaced often because the porcelain comes off. Where can I get another kind of grate to fit the CGB36ru since your price of about $70 times six is very expensive. What keeps...
Hi steve tell...
I would measure the inside of the grill and go to a welding shop and have them make me a stainless steel grate made from expanded metal that would fit my grill and never go back to the porcelain coated grills and their sticking,cracking,rusting again.
It will be somewhat expensive, but it will be worth it and it will be a one time purchase.
Most of the porcelain grills get faults in the porcelain from heating and cooling that allows greases and salts from cooking to seep into and get behind the porcelain to rust the steel grills that the porcelain is bonded to.
That is what causes the porcelain to pop off...the rust.
Please take time to rate me
Aug 31, 2011 | Thermador CGB36RU Grill
It just starting sparking when I put any porcelain dishes in to re heat. Sometimes a glass mug with etching on it. Not consistent. I put butter in a porcelain dish to warm & it was ok sometimes not
The sparks are caused by metal content in the porcelain -- this is variable from dish to dish. The decorative "etching" which is sparking has metal in it as well.
Charlie
Jan 08, 2011 | Microwave Ovens
How do I clean my grill?
Use a grill brush, if you have porcelain grates then use brush for porcelain. If you have cast the wire brush one works great. Don't use wire brush on porcelain it will scrap it off.
Mar 03, 2010 | Weber Genesis Silver C Grill
Can you file the opening to make it larger for a new faucet on a 14-year-old porcelain sink?
try a rotozip with a porcelain bit u can get both at lowes hardware use water to cool when zipping
Dec 14, 2009 | Lacava Design DROP IN PORCELAIN SINK -...
PORCELAIN SINK UNDER GRANITE
Hi just unscrew from under sink use construction grade clear silicon screw it back in do not use for 24 hours and it will be ok
Apr 06, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
Please send me the theme porcelain on my email - thanks borge
To download original theme Porcelain, please click the link below:
Porcelain_ P990i
Thank You
Nov 12, 2008 | Sony Ericsson P990i Smartphone
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
