most proboly your drum replace ur drum...or you can clean it first with windex..wait to dry (your drum is the shinny green things underneath your toner.) if that is clean replace your toner.
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs. Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky andcauses the paper to not feed straight. Try cleaning the rollers with methylated spirits.
Did you reset the counter? After you replace the imaging drum, you should reset the imaging drum's
counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
I Open my browser....I signed in to my router as administrator .... Mine is 192.168.1.1 .... I went to status in my router .... Then to local network .... Then to DHCP Clients Table .... This is how I found what printer address the was.... Then I typed the printer ip address into my browser Mine happened to be 192.168.1.105 .... Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration .... I clicked on Print Server Settings I clicked on TCP/IP I clicked on Set static IP address. I changed IP address from 192.168.1.105 To 192.168.1.125 and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run.... Printers & Faxes Right click on Dell laser printer 1720dn Properties. Ports .... Add port .... Double click on Dell Enhanced TCP/IP .... I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125 the clicked OK ....
Right click on Dell laser printer 1720dn Properties....Ports Choose your new port ....
