Question about IDEAL 2503 (CrossCut) Shredder
Destroyit 2503 service manual - IDEAL 2503 (CrossCut) Shredder
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
Aug 27, 2013 | Destroyit 5009 Shredder
Destroyit 2600 manual
Sorry, I need a parts manual for a cross cut 2600 shredder
Oct 04, 2011 | Destroyit 2601-2 Shredder
JUST RECEIVED A NEW SHREDDER BUT THE MANUAL IS PRINTED IN GERMAN. CAN I GET AN ENGLISH COPY?
It's always wise to include model numbers when asking for assistance but you might find help on their website:
Destroyit
Mar 24, 2011 | Destroyit Office Equipment & Supplies
I need a parts manual for destroyit 2502cc shredder
That shredder is obsolete, but you can probably get parts from shredderparts.com
Feb 25, 2011 | Destroyit 2502 Shredder
We have a destroyit 2602 cross cut shredder, when we put the paper to be shredded in, the shredder would go on automatically, now that does not hapeen. we have to manually press the on button.
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Feb 20, 2011 | Destroyit 2602 Shredder
Destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
May 14, 2010 | Destroyit 3102 Shredder
Gears won't turn in forward like a gear or shear pin is broken looking for a service manual
The plastic gears on either side of the drive motor have the teeth sheared off. I just have to find somewhere to buy the parts.
Dec 01, 2009 | Destroyit 4002 Shredder
Destroyit 4104 manual
I know that shredderparts.com has parts for it, but I don't know about the manual for this machine.
Aug 21, 2009 | Industrial Paper Shredders IPS16D
IDEAL 2503 (CrossCut) Shredder Logo
101 people viewed this question
Top IDEAL Office Equipment & Supplies Experts
jasbo
jasbo
Are you an IDEAL Office Equipment and Supply Expert? Answer questions, earn points and help others
