Question about Estate Kitchen Ranges
Pilot goes out when burners are turned on - Estate Kitchen Ranges
  • 30 Answers
SOURCE: SR24
It could be a faulty high limit, you can also check the high limit probe to insure it is mounted securely against the through tube wall in the grease. Also check the burner, there are baffles that run through it and when they get old the flames don't move though the burner correctly and will cause the high limit to trip prematurely
Posted on Mar 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: burner would'nt lite
Your thermophile is weak . Replace it
Posted on Jun 13, 2009
roniecon
  • 6826 Answers
SOURCE: pilot goes out when valve is turned on
If it has a wick,then the wick is dry,or is not up enough,if it is not a wick type,then the thermocouple is bad.
Posted on Jan 15, 2010
  • 77 Answers
SOURCE: pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
Tom
Posted on Aug 17, 2010
  • 449 Answers
SOURCE: Burner will not light.
call aservice tech your pilot light might be blocked therefore the pilot flame might not be strong enough to handle the puff of gas when the gas valve opens ps. if the unit is off in the summer spiders are usually the problem. Hope this helps
Posted on Aug 19, 2010
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
Pilot light goes out when gas turned on
I am assuming that you are saying that after you have pushed the pilot knob down and the pilot lites and stay lite and then you turn the knob to turn it to ON the pilot goes out...... Then the Gas Valve is bad and will have to be replaced....... Or if you are saying that the pilot goes out when the burners come on then you may need to replace the Thermocouple because the main burner flame is pulling the pilot flame off of the thermocouple and it is weak and will shut the gas off.... Or You could have a cracked heat exchanger that when the burners are on and then the blower comes ON and is blowing the flame around and blowing the pilot flame off of the thernocouple......which will shut the gas off....and then you will need a new furnace or New Heat Exchanger...... These are the most common problems Hope this helps.....
Feb 16, 2011 | Heating & Cooling
Pilot light goes out when burner turned on
Tom
May 28, 2010 | American Range AF45LP Deep Fryer
Pilot goes out when valve is turned on
Jan 14, 2010 | Reddy RCP80V Utility Heater
The Tstat has a capillary that looks like a thermocouple but it isn't, its a bulb with liquid that expands and contracts based on temperature. A pilot can go out due to a high limit switch being week or getting to hot and that can be shaped like a thermostat capillary or can be simply a disc with a button if even there is a high limit on your stove. There likely isnt. So see the next suggestion.
I suggest lighting the pilot, turning on the main burners while watching the pilot. If the pilot shrinks in size, then check your gas pressures before and after turning it on and seeing if there is a wide variation. I would suggest the pilot is dirty or the pressure regulator is faulty.
Dec 19, 2009 | Grilling
My wolf rage doesn't light anymore by turning a nob
some models have one gas pilot for 2 burner front and rear and there is a small pipe that goes front the burner to to the pilot, the burner has small holes facing the pipe the goes to the pilot that's where you take a paper clip or a safety pin and clear or clean the holes, the same thing on the electronic ignition, but some electronic ignition they have a spark right nest to the burner and by looking at the other burner that are working you can see where it's sparking, and clean in between the burner and the spark.
Dec 12, 2008 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Kitchen Ranges Logo
12 people viewed this question
Top Estate Kitchen Ranges Experts
Dan Webster
Dan Webster
Explain Your Issue
richie46
Are you an Estate Kitchen Range Expert? Answer questions, earn points and help others
