Question about Garden
I have a weedeater series 300 lawnmower. When I prime it, it will run for about 5 seconds and then stops. It burns off the gas from priming it and then cuts off. If I do this about 20-30 times then it will run, but by then I'm too tired to cut the lawn.
  • buzz1057 May 11, 2010
    get a new motor for it
  • Dino Jun 05, 2013
    I had the same problem and I put a hotter plug fresh 93 octane gas and the correct 2 stroke outboard oil gas additive and have had no more problems lukes oil also e s gas
    Problem Solver:
  • 15 Answers
Thats a common problem with those briggs motors. There is a plastic tube that goes from the back of the carb to the other side of the motor. There are two small bolts that hold the tube down opposite the carb end of the tube. They loosen over time allowing to much air to get in. Also the tube cracks but not to often. If that doesn't help you need a kit that comes with a gasket and a diaphram. you may need that because the tube warps were it meets the carb. That should fix it.
Posted on Apr 22, 2010
The tube that goes to the carb is broke on the other side of motor
Posted on Oct 05, 2009
    Problem Solver:
  • 14 Answers
It could be a weak plug, dirty filter, or a crack in the primer bulb. If you keep priming once the mower is running, you should check the bulb, which you can get at you'r local small engine shop.Also, make there is no water in tank. if mower is old, you might have to replace the carburator diafram.
Posted on Jun 19, 2009
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Sep 05, 2010 | Craftsman Garden
3.5 HP Lawnmower engine and it rus for only 30 seconds
Sounds like you will need to clean your carburetor even tho you said you alread did.
Make sure to blow out all the jets with compressed air, beware of small parts sometimes in the jets such as seats for the fuel float jet seat.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Jul 31, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
My lawnmower will not start. If primed many times, it will burn the gas that is primed, then stop. New plug, air filter, gas, and oil.
You need to remove and clean out the carburettor and depending on the type of carb, renew the diaphragm if there is one in it. Stephen.
May 06, 2010 | Toro Lawn Mower With Toro Power Tools
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Jun 18, 2009 | Garden
Garden Logo
2,196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
