Panasonic sa-ak28 aux to small - Audio Players & Recorders
My blue ray / dvd player surround sound won't stay on when I have it on AUX for the TV. Model # SA-BTT195 (?)
What do you have plugged into the AUX port?
Have you tried HDMI 2 some tvs have a smart link on HDMI 1 that auto wakes the component connected to it but I dont know your situation.
Sep 20, 2014 | Panasonic Televison & Video
How to hook up a ipod to a panasonic SA-PM19
The way I do it is to run a line between the Aux In RCA jacks on back of the SA-PM19 and the earphone jack on the iPhone, iPod, smartphone or MP3 player.
Apr 13, 2012 | Audio Players & Recorders
I have a panasonic sa-ak58 sterio system and woud like to pug my mic into it. how do i do so
Hi
You would need to buy a small mixing desk which would plug into the AUX input at the back of your Stereo. Your microphone would plug into the Mixing desk.
Good luck. Michael
Aug 24, 2011 | Coby CM-P35 Consumer Microphone
Panasonic model no sa ak 67 aux not work please makenic in bokaro
my set model SA-AK67
its cd mechanism motor is not working.supply ic coming from main pcb to cd loader ocb.please advice
Apr 12, 2011 | Panasonic SC-AK24 CD Shelf System
Product : DVD stereo system Panasonic sa-vk925d The problem is, in aux mode the volume is less than other modes how could i make louder that?
Aux is an input, not a mode. Look to the source that is connected to it. If it's PHONO, the sound will be very low (useless) and tinny without a phono preamplifier in line with it.
Apr 08, 2011 | Panasonic Audio Players & Recorders
Can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Feb 14, 2009 | Panasonic (SCEN25) Shelf System
Hi, I have a Panasonic SA-EN9 digital radio / CD player ect shelf system. I want to play music from an mp3 handheld player through it, and I see that there is an AUX jack in the back of it. I can connect...
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Jul 11, 2008 | Audio Players & Recorders
Cd player not working
  1. its eye unit may in trouble, clean eye by using a eye cleaning cd
  2. eye alignment is failed, adjust the eye by adjust the screw on the eye
  3. cable may loose contact, re fix cable, check cable replace cable if necessary
  4. low power supply problem, check supply voltage, if it low simply add a filter capacitor of 4700uF/40V accross it.
  5. some time its main board may problem, check and replace it
Jan 16, 2008 | Audio Players & Recorders
When we try to play a disc frpanasonic sa-ak28
CD lens may be defective or just need cleaning.
Dec 10, 2007 | Panasonic SC-AK33 CD Shelf System
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Dec 08, 2007 | Panasonic sa-ht930 Home Theater Audio...
48 people viewed this question
 Grubhead
Grubhead
