Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lid Switch I have a Kenmore model 110.29812890. I have what I believe to be a bad lid switch since it fell apart. I need ot replace the lid switch, but am clueless as to how to disassemble the washer to change this. Can you lend some assistance?
    President:
  • 1,136 Answers
HI, The part# is 3949238. There are two ways to replace this switch. The easiest is to remove the two screws holding the lid switch. Pull the switch out enough that you can clip the wires at the switch. Cut the harness off of the new switch leaving enough wire to put wire nuts on connecting them together.
The other way to change the switch is to remove the cabinet. Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can see the lid switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 18, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
Kenmore washer model 110 26712690 fills up with water and does nothing. wife said she smelt something burning. I thought maybe a belt but when I took it apart I didnt see any belts.
no belts in a kenmore,if it filled with water and stopped most likely you have a bad lid switch.close the lid,open it up a few inches and close it down a few times,if you don't hear a clicking sound every time you open and close it the lid switch is bad.,if you already have it apart,you can jump it out,the white harness you disconnected next to the right clip is the lid switch harness,stick a wire in the two outside holes,put it on spin and pull the timer out,it will run.the model number you sent isn't correct,i was gonna give you the part number and price of the switch,just give it to your parts store and they will sell you the correct part.
May 15, 2011 | Kenmore 22422 Top Load Washer
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
I have a kenmore washer model 110.82467800. It won't drain or spin. It does everything else but it won't drain or spin.
This is most likely due to the lid switch being bad. The machine is designed not to go into drain or spin with the lid open, if the lid switch is bad, the machine may think the lid is open. Here is a link to a video that shows how to replace the lid switch.
No Spin
Aug 22, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
I think it is the same proble as you discribe
Hey chiki76
You still have a lid switch problem. The switch has to be replaced. The switch usually comes apart or the clips securing them are broken
regards
Sep 04, 2008 | Kenmore 22422 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
Apr 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 110-24632300
check the lid switch it is on the top under the lid it may have cracked and fell off
Nov 09, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
139 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
