Question about Whirlpool Calypso GVW9959K Top Load Washer
Squealing when filling.
During the latter stages of a wash cycle, as the tub begins to fill with water, a loud squeal develops from the rear of the washer. I've discounted air in the lines, the faucets are fully on, so I'm guessing it's the water inlet valve. Does this sound reasonable?
If so, is the part easily accessible or is this one of the washers that you open like a Japanese puzzle box?
Thanks.
Mike.
  • 332 Answers
There is a loose washer in the valve and the water is gong behind the washer therfore makeing the sound,, change the shut off valve and you will no longer have a sound,, good luck,, and make sure you trun off your waer to your house before removing the valves
Posted on Jun 23, 2009
VERY LOUD SQUEAL and SQUEAK right before the RINSE cycle. it's scaring me! thanks for your input.
Hi Margaret,
Does the tub/drum come to a complete stop prior to the rinse cycle beginning? Are there any belts or is it direct drive? Does it pump the water during the rinse cycle? If nothing is moving it could be the impeller on the pump is slipping, but likely it would have already come loose. The pump itself usually just fails completely without the squealing and squeaking part. If someone could be sure nothing is pushed up against any other moving parts it would be of help. It often happens when belts are involved and the drum is being turned it does just what you are describing, until it gets to speed.
May 17, 2016 | Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a Fisher Paykel Model GWL11. It is squealing very loudly during the fill cycles. I am afraid the water pump is going out?? Any ideas?
Hi Chris2483,
I have come across this before. It is the water inlet valves. Replace these and your all set.
Feb 28, 2011 | Washing Machines
I have a GE model number WHDSR109J8WW washing machine. It works well, but there is a metal on metal squealing sound that occurs during the wash cycle and sometimes the rinse cycle. It works perfectly in...
First you take off the front cover of the Machine that is held in place by two clips at the top. then you look at the bottom of the frame assembly that holds the motor. You will find that when the Machine fills with water and clothes the tub drops way down!! and the frame rubs on the bottom pan of the washing Machine. My machine was new!!! and I made two Pads from the old washing machine feet and put them through the two holes in the frame and put a little grease on them and it works like it should GE your engineers should have seen this!!!!! Thank You FROM K.C.Morris God Bless America
Jan 21, 2011 | General Electric Washing Machines
My machine (GWL11) is making a very loud squealing noise. I notice it when it is first filling up, and then later during the wash. It isn't my water lines. The tub also has a sour water smell most of the...
Hi there it will most definately be the pump, if you look under the machine or in the hatch, you will see on the right hand side the pump, spray some CRC or WD40 on it, it will be awesome after that :)
Dec 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
The washer squeals as the water is filling the tub and continues through most of the cycles. As the machine agitates quickly, the squealing stops. However, it squeals at the end of the cycle.
Sounds like the pump.  When it first fills the pump recirculates the water, then it comes on at the end of each cycle to drain the water.  The pump is on the bottom of the machine, on the right side.
Dec 19, 2009 | Fisher Paykel EcoSmart GWL15
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Squealing sound
hi there,
the squeeling could be either the rear tub bearing or the the hub seal kit needing replacement. have you had a technician take a look at it?
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
145 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
