Question about LG Washing Machines
Hi i have a LG washing machine WFT8061DD , its their latest direct drive top loader , can u please tell me if it has an auto restart function or not. because in my area i have a lot of power break downs. please please tell me at haseebnassar@hotmail.com
SOURCE: lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Posted on Dec 10, 2007
jan mczeal
  • 632 Answers
SOURCE: Hi my LG 8kg top loader washing mashine says UE
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Posted on Oct 19, 2009
  • 67 Answers
SOURCE: I need an Operating manual for LG 7kg Direct drive
They are freely available from www.lg.com look in support, you will need the model number off the detergent drawer.
Posted on Apr 19, 2010
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
My lg direct drive washing machine is leaking during the wash cycle. everything else is performing normally. what is wrong?
You didn't include model number, but if this is a front loader try taking top off and do a load. You may be able to see where the leak is. There are several hoses that could be cracked or loose. Also check pump filter clean out. Good luck.
Mar 14, 2018 | LG Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
LG Inverter Direct Drive 7.5kg Front loader WD12020D
purchase a couple of washing machine cleaners from a local supermarket or homeware store. there will be on the console two buttons with a * next to them, turn the machine on and press both these buttons. the machine will display "tcl" normally, insert 1 cleaner into the drawer where detergent goes and press start. run a couple of times to make sure it has all flushed through
Apr 10, 2014 | Washing Machines
Lg wth 750 washing machine top loader
The instructions for your washer may advise what type of detergent to use and how much. If not, refer this issue directly to LG.
Jan 01, 2014 | Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
Washing Machines Logo
112 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
