Question about Maytag MBL2256KES Stainless Steel Bottom Freezer Refrigerator
Freezer making grinding noise ice maker not working
The noise stops when you pull the freezer drawer out. It is a Maytag with freezer on the botttom. Model #MBL2256KES Serial 10523314JL
  • 23 Answers
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Posted on Jun 19, 2009
Mbf2256heb maytag fridge My fridge seems to cool properly, but it is making this nearly constant buzzing or grunting sound that stops when you open the freezer (bottom) drawer. Suggestions?
Is you unit hooked up to water because if your unit has an ice maker and not hooked up to water currently, the ice maker will call for water about every 45 mins and cause this noise. To stop this action, lift the bail arm to the off position to avoid or stop this from occurring.
I hope this helps.
Oct 24, 2013 | Refrigerators
Ice maker making a grinding noise. I remember a
Yes - if the noise does not stop - please re-post.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Frig is driving me crazy---weird noise and no ice!!
That might be the fan. Making that noise, because fan stops when you open the freezer. The ice maker might be a totally diffrent problem. The solenoid may not be opening to let the water in, which is usually cause by a bad solenoid.
Nov 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker grinding sound
I found I get a odd clicking noise whenever the icecubes freeze inside of the box in the top left. You'll see about 20 little fingers, arms, or whatever you want to call them that spit out the ice into the container...make sure those fingers/arms arent stuck from the ice.
Jun 11, 2008 | Maytag MSD2651 HE Side by Side...
Freezer Not making ice
are u getting water to the icemaker? If Not check water valve for ice maker in back of refrig.
Sep 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
Maytag MBL2256KES Stainless Steel Bottom Freezer Refrigerator Logo
271 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
