Question about Acer Aspire 7720 Notebook
Acer 7720 wont boot no bios
No bios
4 Suggested Answers
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
zohail
  • 1223 Answers
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Posted on Mar 02, 2009
  • 76 Answers
SOURCE: Can not start Acer Aspire
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Posted on Nov 22, 2010
Reset BIOS? how to
With both PC and LAPTOP Motherboards,Pc Motherboards are easier to Wipe Passwords than laptops because of ease of getting to the Jumper on the motherboard normally by the battery on the motherboard.I would suggest looking online for the motherboard manual which should show you where the bios reset jumper is.Laptops are just the same but a lot harder sometimes to find this jumper. Hope this helps
Aug 26, 2014 | Acer Aspire 7720 Notebook PC
NUMERIC KEYPAD NOT SUPPORTED
Might give this a try-right click on your Computer icon-click on Properties-then click on Device Manager. The keyboard is listed there. If it has a yellow exclamation point, or a yellow question mark, then there is a problem. Click on the arrow in front of Keyboards, then right click on the drop down named keyboard. There you can click on update drivers. That should solve the problem.
May 07, 2014 | Acer Aspire 7720 Notebook
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Will not reboot
Get into BiOS , select to boot from CD/DVD and use Acer's restore CD's to restore your system.
Nov 24, 2011 | Acer Aspire 7720 Notebook
When the machine is cold it wont boot up on first attempt. you have to switch off using power button. it does this for 3 or 4 times. on the odd occasion when it does work on the first or second attempt it...
Hi , this is a common problem with Acer notebooks ,they are buggers for shipping laptops without fully testing bios firmware.
I have had this on numerous customers computers , its a simple fix just visit Acer Support to download latest firmware.
Hope this helps
Dennis
Wise PC Callout
Feb 18, 2009 | Acer Aspire 7720 Notebook
Acer 7720 will not boot
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
7720 will not boot
pls go step by step
Jan 30, 2009 | Acer Aspire 7720 Notebook PC
Acer notebook 7720
if its brandnew, take it back, its under warranty !
Dec 12, 2008 | Acer Aspire 7720 Notebook
Acer Aspire 7720 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
