Question about Gateway 17.3" NE71B06u Laptop PC with AMD E1-1200 Processor and
Why does it get to Gateway logo and stops loading?
Tells me also to unlock something that I can't get to since unit wont load!Finally got it to load F2 screen!
  • Zrah Rasul
    Zrah Rasul Apr 16, 2016
    Press power button to boot, immediately press F2, this will bring you to your Bios or system setting, you can configure your system to boot to CD/DVD, save by pressing F10, exit, your system will attempt to boot to a CD/DVD, but advanced options will be available for recovery options also, i.e., restore points or system reset. Hope this helps.
  • Zrah Rasul
    What happened when the F2 screen loaded?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
The system BIOS is probably good, but the operating system is most likely corrupt.
Posted on Apr 23, 2016
  • 81 Answers
SOURCE: windows does not load after gateway logo
This sounds like you have no operating system on your laptop. I bet someway, just as I did before, you have lost your operating system, and it needs to be reinstalled on your computer.
Posted on May 30, 2008
leecom72
  • 4806 Answers
SOURCE: Gateway PC error
Hi there
If you can get into the bios set it to default settings and reboot the laptop, it should let you through to windows
post back if you get the same result
Kind regards
Posted on Jan 05, 2009
  • 109 Answers
SOURCE: wireless wont turn on using F2 key. is this
There is a physical wireless switch on the left side of the computer. The switch turns both the wireless network adapter and the bluetooth on and off. You need to first make sure that this switch is on.
With switch in the ON postiton, then you can use the FN-F2 keys to toggle the wireless LAN on and off.
The wireless adaptor is probably a mini-pci card that can be access through a panel on the bottom. Wireless cards on laptops are not considered user-replaceable so Gateway does not show where the panel is or if it's mini-pci card. If there is a panel other than the hard drive and memory then that is where the wireless card is. They are not hard to replace though it's best to try to replace it with an exact model.
If the computer is in warranty, they Gateway will have you send it into their service depot to have it replaced,
Posted on Dec 30, 2009
  • 811 Answers
SOURCE: When I turn on my
Beeps usually indicate a problem with your hardware memory chips or keyboards or other items that are not functioning properly. I suggest if it is still under warranty send it back if not take it to a good shop for repair. Or try reinstalling the original software I would do this first. Most likely it is a memory module the way to test this is remove one of the chips and try starting the computer. If this continues place the one you removed back in the computer then pull the other one if it boots you have found your memory module that is bad if this is the issue, make sure that you have everything plugged in. John
Posted on Jan 15, 2011
shibuda
  • 1812 Answers
SOURCE: Hi i have a gateway
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
Posted on Feb 26, 2011
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
TABEO PRE LOADED APPS GONE!!
I tried to unlock my tablet but it wont let me , so how do I reset my tablet. PMID921X
Dec 26, 2013 | Toys R Us Tabeo
Gateway NV56R14u windows 8 wont load pass the gateway logo and if it does it will go to a blue screen and say no bootble device then it will say windows boot manger failed to load
Did it come with Win8 installed already? Was it ever working before? Or did you install Win8 on this machine and now it won't boot up?
Oct 20, 2013 | Gateway nv Computers & Internet
The videos only loads up for 6 seconds, then stops loading
Youtube videos wont load fully! They only play one third of the video at a time. I have a new computer, plenty of memory and my internet speed has just been checked at 7500 kbs.
Any ideas?
Jul 20, 2009 | YouTube Videos
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Please Help Me!
Yes your asking too much of it,
An old system cannot keep up with all the memory intensive programmes and the processor will not cycle the information fast enough for you
This is why it is slow
add more ram, bigger hard disk drive too will help
if you can
delete anything off it you can too
increase the page file size,
will help
Regards
Richard
Apr 25, 2009 | Gateway Essential 466 PC Desktop
Laptop turns itself off and wont come back on.
i have a gateway m675 laptop and i need to brighten my screen
Mar 30, 2009 | Compaq Presario V4000 Notebook PC
Washer stopped after filling, small load
I would check and make sure the lid is not bent or bowed. If the middle part of the lid is too far down when closed, the machine thinks it's open and wont run an agitate or spin. If it is bent, just bend it back for a quick fix.
Dec 03, 2007 | Amana ALW880WH Top Load Washer
Gateway 17.3" NE71B06u Laptop PC with AMD E1-1200 Processor and Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
