Question about NordicTrack E4000 Treadmill
When I plug in the treadmill, the display comes on for a second and goes off.
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Dec 06, 2013 | Exercise & Fitness
My treadmill wont re-boot
    • 3
    • 4
    • 2
Nov 11, 2013 | Epic A30T Treadmill
I have a sportscraft treadmill it come p. fine run for a few seconds and goes off. The screen had a 3 on it when it goes off. The fee seconds it does run it seems fine
7eef0c0f-9fee-4743-8c0c-d60deca9fbdb.gif1) tight and clean the upper and lower connector
2) tight and clean the ribbon cable for display board
3) adjust the Reed swtich , tight and clean and test for faulty or open
see the diagram attached.
4) lube the deck belt see the video.
God bless you
Nov 03, 2013 | Exercise & Fitness
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Precor 9.35 won't stay on.
you must replace the control board electronic.
Go to www.treadmilldoctor.coa5bb443a-9b01-48c9-9230-29270afbdc24.gifm
and get it see the diagram how the control board control almost the 80% of the machine.
God bless you
Sep 18, 2013 | Precor Exercise & Fitness
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack E4000 Treadmill Logo
22 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
