Question about LG Computers & Internet
Goes to power saving mode immediately.
My 23' flatiron monitor switches to power saving mode just a few seconds after I boot up my PC. I turn on my PC, then the red blinking light (which all monitors do I expect) switches to a non-blinking state when I turn on my PC, which proves that it "recognizes the PC booting up" but then immediately switches to power saving mode. I have another smaller monitor and tested my PC using that. No problem there. So there's an issue with my monitor. My power supply did short out yesterday, and died (there were a couple sparks), so that PC is inoperative. Could this have somethign to do with it? how do I fix this?
SOURCE: Going to Sleep
got the same issue
hp pavilion 1723
Posted on Feb 02, 2008
Mark_Webber
  • 472 Answers
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
pravinbhavsa
  • 348 Answers
SOURCE: Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Posted on Oct 29, 2008
SOURCE: Monitor automatically clicks into power saving mode
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Posted on Apr 22, 2009
  • 9 Answers
SOURCE: Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Posted on Oct 01, 2009
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Princeton LCD17 blinks off immediately
Check the VGA cord that connects from the PC to the LCD, try putting VGA cord properly to the LCD and PC, or change the VGA cord. saving mode indicates no signal from the PC. So either the PC is not booting up or VGA cord faulty.
Nov 09, 2008 | Princeton Digital VL1918 Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
