Question about Datamax Office Equipment & Supplies
Printer will not print
I have a data-max-o'neil that is giving me a message to replace media 210 what does that mean?
    Scholar:
    New Friend:
  • 52 Answers
There's a "Media Sensor" in the Datamax that is evidently having trouble seeing the labels. The sensor is inside of a horizontal bar above the labels and just behind the Printhead. That bar is movable. Make sure that the vertical mark, usually white, is positioned over the label - best if it is the center of the label. Also make sure that there is no label or ribbon material stuck in that area. Hold "Feed" button down for a few seconds after checking those two things to "Re-calibrate" the sensor.
Posted on Apr 17, 2014
SOURCE: glow lite on; replaced drum and toner; printer is on and printing
how to reset the toner light to replace the new one
Posted on Apr 29, 2009
psycondric
  • 42 Answers
SOURCE: Display shows "check printhead"
Hello Neil, If the quality of print is fine then i dont think there is a problem with your printer head. It must be some error with the software or some other part in ur printer. Do check the printer for some other faults.
Posted on Jul 08, 2009
  • 191 Answers
SOURCE: Canon smartbase MP360
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Posted on Oct 05, 2009
  • 1570 Answers
SOURCE: My printer stopped printing? Canon Pixma 210 New
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Posted on Apr 20, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark T640 printer will not print- get message- media tray empty
    Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
    Posted on Aug 30, 2012
    Canon Pixma 420 won't print after cartridge is replaced
    make sure you are using good quality ,correct number cartridge and insert properly?
    switch off printer and change data usb cable, then switch on the printer, it will work, again same ,,must be check ink carriage cable is damage?
    Apr 20, 2017 | Canon PIXMA MP780 All-In-One InkJet...
    HP 4350 ERROR MESSAGE: 49.2F90
    "the printing operation has been aborted.
    The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
    Action :
    1> Press Cancel Job to clear the print job from the printer memory.
    2> Turn the printer off and then on to clear the error message.
    3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
    If the above action does not solve the issue, contact HP or authorized service provider."
    Mar 15, 2008 | Office Equipment & Supplies
    T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
    This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
    Please try to do the following
    ? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
    ? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
    ? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
    For further assistance, please contact Lexmark Technical Support.
    Aug 02, 2011 | Lexmark T632 Laser Printer
    34 short paper error
    • Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
    • Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
    • Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
    Apr 21, 2011 | Lexmark C543DN Laser Printer
    I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
    SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
    if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
    Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
    Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
    Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
    Jul 08, 2009 | Canon imagePROGRAF W6400 InkJet Printer
    Can I use only a black BJ cartridge on a Canon 620 printer?
    Nope. You can use Cyan, Magenta and Yellow as well as Black.
    Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at PrintCountry.com
    Canon.com's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    85 people viewed this question
    Top Datamax Office Equipment & Supplies Experts
    Dave Busselle
    Level 1 Expert
    Starnley Johnwells
    Starnley Johnwells
    Joseph Mueller
    Joseph Mueller
    Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
