Question about Dell Inspiron E1505 Notebook
Inspiron E1505 - ac power not always on when plugged in outlet
Plugged into ac outlet, but the green light on 'battery' not always on - have to remove the plug (not fromt the wall or the laptop) or jiggle the cord that goes tfrom the 'battery' to the outlet to get light to come on.
How do you tell if it is a bad cord or bad battery or what This just started happening
Thanks
    Problem Solver:
  • 11 Answers
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Posted on Jun 19, 2009
  • Dell Master
  • 32,281 Answers
The most likely problem is the power socket on the laptop, it may be just a dry solder joint and needs to be resoldered or it may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars. If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Posted on Jun 18, 2009
My laptop screen dark but working
Hi zangoka,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Dell Inspiron E1505 Notebook
Dell 1505 fan runs screan blank has two flashing lights
Hi frase809,
Hope it helps.
Feb 05, 2011 | Dell Inspiron E1505 Notebook
When i plug my ac adapter the screen flickers a couples of time then i goes black
Hi grice2000,
Hope it helps.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Computer will not start
In my opinion, if the motheroard is dead and it is an older laptop, it is now spare parts. BUT first, try another power adapter to make sure that is not the problem. You do not want to replace the motherboard with the same one, you should want to upgrade the MB. But laptops are one of a kind deals where a newer, better MB just won't fit. So after you have checked to make sure it is not something simple to fix, consider a newer laptop.
May 25, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook will not power up..
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 19, 2009 | Dell Inspiron E1505 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron E1505 Notebook Logo
162 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
