Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
What type of oil goes in Troy-Bilt 26cc tiller?
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 69 Answers
SOURCE: What type oil goes in the tranmission?
80W90 Gear oil goes in the tranny. 30W is for the engine only,
Posted on May 06, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
  • 1706 Answers
SOURCE: troy-bilt cultivator 26cc gas/oil separate
Hi, Check the oil reservoir breather that it's not plugged up. The oil should be returning back to the reservoir not going to the filter. That tells me that there is air being pumped into the engine (oil).
The piston rings could be broken or the carberator needs to be readjusted.
Open the air screw abit more on carb. Then see what happens. Good luck.
Posted on Jul 30, 2011
  • 316 Answers
SOURCE: primer bulb
hello take the old bulb and go to your local mower repair shop,,
Posted on Feb 21, 2012
Troy- bilt electric cultivatar tb154 wont start. Could it be the overload protection button?
it could be the overload protector or the electrical cord has broken inside so it isn't getting the power it needs or the brushes in the motor have gone out
Mar 28, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
PRIMER BULB ON TROY BILT 144 TILLER WILL NOT FILL
look for a cracked fuel line or a split in the primer bulb
May 17, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Primer bulb
Feb 01, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy-bilt cultivator 26cc gas/oil separate engine spewing oil out through filter when running...there is a hose from the oil reservoir straight into the back of the filter...as the engine revs it literally...
Jul 30, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
What kind of oil goes in crankcase
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Mar 22, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy built cultivator will only idle 26cc 5yrs old
Problably not sucking air, but not getting enough air. Does your cultivator use gas/oil mix or straight gas? If it is a gas/oil mix the muffler is probably stopped up with carbon and cutting off the air flow. Try removing the muffler and see if it runs better.
Jun 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
65 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
