Question about RCA D52W19 52" Rear Projection Television
The picture is red, does this mean a bulb has burned out ?
Which bulb would it be ?
  • 97 Answers
There will be three bulbs, red blue and green. if the display is red, than one of the contrasting colors is shot, more likely the blue.
Posted on Jun 18, 2009
No Picture. On/Off light starts out red then immediately turns white, then the white light blinks 7 times about a second apart. Then no picture-no sound but the TV does appear to be turned on. Fuse S2 was...
Have you tried the manufactures web site to decode what the flashing lights may mean? Not knowing the manufacture it could be simply a burned out bulb.
Nov 12, 2014 | Televison & Video
Wont power on
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Wd60c9 lights blinking green sometimes,then yellow and finally red and no picture for any significant length of time
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
Feb 23, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
Yellow screen
my picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
Jan 22, 2013 | Philips Sony KDF55WF655 KDF55WF655 Lamp...
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
No picture coming out
where is the red flashing light comming from is there a image or text saying what it means?
but to be hinest i belive that the bulb has finished and died
May 13, 2010 | InFocus ScreenPlay 4805 Multimedia...
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have sound but no picture, then shuts off and lamp light goes blinking red? HELP!
You have to count how many times it blinks. This is a code to tell you what is wrong.
Dec 12, 2009 | Mitsubishi WD-60735 Projection Television
Green bulb does not burn at all, can it be changed
This is a CRT (or picture tube) projection TV . and if the green CRT won't come on it doesn't mean the crt is bad. The red or ble CRT could be put in the place of the green one to confirm if the tube is bad . It is more likely that the voltages feeding the green crt (middle CRT) are bad or missing. In either case it takes a bit of troubleshooting and disassembly to confirm. A CRT costs between $200-$500.
Sep 28, 2009 | Akai PTH5498 54" Rear Projection...
No pic with sound and turn off by itself with a
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Jul 01, 2009 | Mitsubishi WD-60735 Projection Television
RCA D52W19 52" Rear Projection Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
