Question about Nebo Camping, Backpacking & Hiking
Headlamp wont turn off - Nebo Camping, Backpacking & Hiking
2008 Saturn aura wont start after trying to put rt.low lowbeam replacement
On the inside of the lid is a diagram .
The headlamps may be turned ON 2 different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the AUTO position, for automatic lamp control (ALC). During ALC, the headlamps will be OFF in daylight conditions, or low beam operation in low light conditions. Battery positive voltage is supplied to the low beam relay and the high beam relay in the underhood fuse block. When low beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the low beam relay. This activates the relay and the relay supplies voltage to the left hand low beam headlamp through the LH LOW BEAM fuse and to the right hand low beam headlamp through the RH LOW BEAM fuse. Ground for the left hand low beam headlamp is provided at G101. Ground for the right hand low beam headlamp is provided at G102. When high beam headlamps are requested, the body control module (BCM) supplies ground to the coil side of the high beam relay. This activates the relay and the relay supplies voltage to the left hand high beam headlamp through the LH HIGH BEAM fuse and to the right hand high beam headlamp through the RH HIGH BEAM fuse. Ground for the left hand high beam headlamp is provided at G101. Ground for the right hand high beam headlamp is provided at G102.
Aug 14, 2017 | Saturn Cars & Trucks
2008 chevy trailblazer headlights wont go off for 15 minutes when engine is turned off
https://s17.postimg.org/fziahwj27/headlamps.jpg
Click on the link.
I don't know if this info will help? Can you operate the headlamps in the manual position, instead of auto position?
Do you want the wiring diagram?
Jul 21, 2017 | Cars & Trucks
2007 chev sub head lights wont turn on
Do you know anything about automotive electronics ? Electronic control modules .
Headlamp ON/OFF control is determined by the body control module (BCM) by a signal on the headlamp switch on input circuit when the headlamp switch is in the HEAD position. When the headlamp switch is in the AUTO position, the BCM determines headlamps ON/OFF by the voltage from the ambient light sensor.
If the headlight switch is left in the ON position, the inadvertent power control feature will turn OFF the headlights approximately 10 minutes after the ignition switch is turned to the OFF position. If the driver places the headlight switch in the ON position after the ignition switch has been turned OFF, or if the ignition switch is in the ACCY position, the headlights will remain ON until turned OFF or the battery runs dead.
The high beam indicator is illuminated when the instrument cluster receives a GMLAN serial data message from the BCM that the high beams are illuminated.
High Beams
The high beam headlamps receive voltage from the headlamp high relay located in the underhood fuse block. The BCM controls the relay on the headlamp high beam relay control circuit. High beam control is determined by a signal on the headlamp dimmer switch signal circuit from the multifunction switch. When the headlamp dimmer switch signal circuit is grounded, the BCM grounds the headlamp high beam relay control circuit, illuminating the high beam headlamps. The right and left high beam circuits are independent and are fused independently in the underhood fuse block.
Low Beams - Standard
The low beam headlamps receive voltage from the headlamp low beam relay located in the underhood fuse block. The BCM controls the relay on the headlamp low beam relay control circuit. Low beam control is determined by a signal on the headlamp dimmer switch signal circuit from the multifunction switch. When the headlamp dimmer switch signal circuit is open, the BCM grounds the headlamp low beam relay control circuit, illuminating the low beam headlamps. The right and left low beam circuits are independent are fused independently in the underhood fuse block.
Hooking up a factory scan tool an checking DTC'S - diagnostic trouble codes would be the very first step in trouble shooting this problem .
DTC B257A 00: Headlamp Switch Input Signal Mismatch
DTC 2575 00: Headlamp Control Circuit
Jun 30, 2017 | Cars & Trucks
Hi my name is Larry I have a 1998 Pontiac sunfire & my problem that I have is I have low beam. But no high beam.
It's probably the switch , but testing to know for sure is alwasy a good idea .
Headlamps Inoperative - High Beams
Step
Action
Value(s)
Yes
No
Did you perform the Daytime Running Lamps (DRL) System Check?
YES - Go to Step 2
NO - Go to Daytime Running Lights (DRL) System Check
Disconnect the turn/hazard headlamp switch connector C1.
Connect a fused jumper between terminal B of the turn/hazard headlamp switch assembly harness connector C1 and ground.
Do the high beam headlamps operate?
YES - Go to Step 3
NO - Go to Step 4
Replace the turn/hazard headlamp switch assembly.
Did you complete the repair?
Repair the open in CKT 1200 between the turn/hazard headlamp switch assembly. Refer to Wiring Repairs in Wiring Systems.
Step
Action
Normal Result(s)
Abnormal Result(s)*
Turn the headlamp switch to the HEAD position.
Turn the headlamp dimmer switch to the LOW position.
The low beam headlamps are ON.
The high beam headlamps are OFF.
Headlamps Inoperative - Low Beams
Turn the headlamp switch to the HIGH position.
The high beam headlamps are ON.
The high beam indicator is ON.
The low beam headlamps are OFF.
Turn the headlamp switch OFF.
Turn the ignition to ON.
Disengage the parking brake.
The high beam headlamps come ON at a reduced intensity in approximately 30 seconds.
Daytime Running Lamps (DRL) Inoperative, Headlamp Switch Operates Normally
* Refer to the appropriate symptom diagnostic table for the applicable abnormal result.
Jan 13, 2017 | 1998 Pontiac Sunfire
Head lights wont turn off 06 h3 hummer
If you pull the headlamp relay in under hood fuse box, that should kill the headlamps until you figure out the problem? I don't know if relay could be faulty? I'd want to check relay wiring circuit for ground?
Your bcm grounds the coil side of headlamp relay in order to energize. I'm not saying bcm has a problem? The bcm receives input from headlamp/dimmer switch telling it the headlamp relay should be grounded. You might check for bcm or communication trouble codes.
Oct 15, 2016 | 2006 Hummer H3
1996 ford explorer and the lights wont go off when i turn off the engine remove the key and turn the light switch to off. I have to remove the battery every time I stop the negine. I think it has something...
Are you talking about headlamps? If you pull fuse 11--20 amp, underhood fuse box, do the headlamps go off? Right now, I'm thinking something wrong with head lamp switch. Maybe the wiring connector has a problem or circuit is shorted to voltage. With the headlamp switch in the off position, there should no voltage for headlamps. As you can see, that fuse I mentioned is hot all the time. Just my opinion.
May 13, 2017 | 1996 Ford Explorer
Died now wont start
The security system need to be reset, plug your charger back on the battery then turn the ignition switch on and leave it on untill the security warning light turns off (about 10 to 20 Min) then turn the key to off wait 5sec then turn the car on it should be good to go, this solves this kind of problem 9 out of 10. good luck
Oct 12, 2012 | 2001 Ford Escape
Our headlights wont turn on. Is there some way we can check this problem, thanks D.Bonchek
check to see if power is at headlamps with switch on. if not check the fuses, there should be a left headlamp fuse, as well as a right headlight fuse.in underhood fuse box. if the fuses are ok. then it may be in the wiring or the switch. check the switch for power when turned on.
Jun 01, 2011 | 1999 Chevrolet Malibu
Hello i am experinceing some problems with my 2003 toyota corolla first my run light stay on with the key off the key out of the ignition i gather from forums thats the head light switch since it only...
It sounds like you are suffering from a bad case of "Killed The Battery" The ignition switch will not turn your headlamps off if you leave the light switch turned on. This is a problem I see all the time with "Auto" headlamps. Most people turn the headlamp switch to "Auto" and leave it there. This is fine. The headlamps will stay on a minute or two after the ignition is turned off then they will shut off automaticly. What happens is that the headlamp switch gets turned to the "On" position and when you get out of the car you expect them to turn off automaticly but they don't....Dead battery! Then there's the case where the headlamp switch itself lies to the body computer (The guy in charge of turning the lights off) about which position it is in...You have no idea that it is doing this...Dead battery!
The radio is most likely inoperative due to the battery going dead. It is probaby waiting for you to enter the security code to unlock it. If you don't know the security code you will have to take it to the dealer to get them to unlock it for you. (The antitheft system thinks you were trying to steal the radio when the power went off) The clock is going to be off because it has to be reset just like the clocks at your house when the power goes out.
Jan 15, 2011 | 2003 Toyota Corolla
1999 olds aurora,headlamps wont turn off,sometimes will blink.
those are problems with the olds light switches, same switch used on other gm vehicles. replace it , new or salvage yard
Sep 18, 2009 | 1999 Oldsmobile Aurora
Camping, Backpacking & Hiking Logo
55 people viewed this question
Top Nebo Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Nebo Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
