Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
Startup procedure on a UP6-25-125 Ingersol Rand Screw Compressor
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: ROTARY SCREW COMPRESSOR TRIPPING
Possibly water in the air tank ? Or Ice covering the inlet or screen into the tank? DOes it have a belt? or direct drive? Remove the belt and try to turn by hand. See if its the motor or the compressor is tight. If it rolls free possible a chack valve is hung up or has a broken spring OR yuo have a bad capicator or centrifical sw going to the start capicator. Check amp draw with no pressure on the compressor. tank open. If it runs extra time its somethign while under load. If it still cuts out you need to sepperate and discover if its a mechanical or electrical problem.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK
Posted on Mar 03, 2009
SOURCE: I am looking for a operating manual for a
Try this link:
http://www.aircompressorsdirect.com/manuals/irup6_15to50manual.pdf
Posted on Mar 08, 2010
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean
compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
Jun 24, 2014 | Ingersoll Rand Stationary Air Cooled...
Excessive oil with air
Replace the oil separator it should work or check the scavange line for blockage
Mar 28, 2014 | Ingersoll Rand Air Tools & Compressors
How much oil for 2420N5
the price of t30 select is 6,000.00 pesos.
May 26, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Mar 15, 2010 | Ingersoll Rand - Rand Type - 30...
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
May 18, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
53 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
