Kobo Where to buy the usb power port 6201 usb-R005
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo n613 not charging, no battery level indication on screen. Changed charger but still not charging. Also, do not know how to remove back cover to access the battery.
I do not have the n613 but please check your USB ports as these some time give a problem when you try to charge your battery through the computer - also check your connects from the e-reader to the computer as this could also be a problem..... if the above still does not work I suggest you plug the e-reader in and try and re update it...
Hope this Helps
Jul 27, 2014 | Kobo eBooks by Kobo
How do i repair the charging port on my kobo arc the cord will not fit?
That's a tough job unless you can send it back.
You can charge it with a USB cable and aPC, however it is slower but it might work.
Try that first.
May 17, 2014 | Kobo Arc
Kobo problems
...back to the company you bought it from, perhaps?
Nov 28, 2013 | Kobo eReader
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
