Question about Refrigerators
How to install replacement control board W1053278, when it will not fit original part number of 12868513
Jazz-board #12868513 has been replaced by what #
USE 12784415 CNTRL-ELEC Whirlpool electronic control board. 12868513 or ERP12868513
Oct 13, 2014 | Refrigerators
About once a month the freezer has to be manually defrosted for it to work effectively.
The problem is most likely the=> 12868513 Electronic Control Board 3_11_2013_2_22_16_pm.jpg
and it could be the 12729128 Heating Element or the defrost thermostat=> W10165425 Defrost Thermostat
Here is a link to a=> GB2FHDXWB Parts Manual and a User Manual HERE The 12868513 Electronic Control Board can be found on page 6 of the parts manual and the 12729128 Heating Element and the W10165425 Defrost Thermostat can be found on page 9 I will be here to tell you how to check out or install these parts if you like, Let me know Thanks Sea Breeze
Mar 10, 2013 | Whirlpool Gold GB2FHDXWB Black Bottom...
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
The refrigerator portion will not cool. The freezer is working properly. I have adjusted the thermostat and it has not cooled off
We need to have a look at the freezer air damper assembly=> 12868513 or the Point and Click 67003426 Defrost Thermostat to inure it is not stuck shut, or
Ice buildup in freezer due to a defective defrost heater, defriost thermostat/termination
switch or the=> 12868513 Control Jazz Board or here=> Appliance 911sea_breeze_64.jpg
Need you first to look inside rear of freezer and see if frost is building up indicating defrost is not taking place. Defrost heater=> 67003426
sea_breeze_66.jpgsea_breeze_67.jpgClick on Appliance 911 above and I will assist here or here with the service manual, Thanks, Sea Breeze
Feb 03, 2011 | Amana ABB1927DE Bottom Freezer...
Hi I have a amana bottom frezer model number abb1922feq that runs all the time even when I turn the controls off the compresser stell runs and the coils freeze up so the Refrigerator dues not work ?
sounds like the control board is bad part 12868513,there is no timer on this fridge and it sounds like it's not going into defrost,this board controls this,it's located in the fridge section inside where your touch pad is,i'm pretty sure you have to take down the light cover to get at it,it's been a while since i've changed one,good luck
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge and freezer at approx same temp warm. Bottom was cleaned as best we could was extremely dirty. What else may the problem be?
Need to unplug and lets inspect the control board inside the fresh food compartment and behind control pane. Fact is it is part of the controls on that model. Look for heat or burn marks but still without signs the board may be not allowing defrost a fan or the compressor to run. If you see ice building on rear wall of freezer unplug and manually defrost so at least you will have colder temperatures until repaired. Part number for the board is 12868513 I will be back shortly with a photo or two, Sea Breeze
Oct 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge and freezer stopped working.Power still on (light on in fridge). Digital control for fridge and freezer shows straight line no numbers. Any suggestions?
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Jun 05, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerator not colling
The freezer vents are electricaly controled as is with most of your refrigerator. Inside the fresh food compartment there is a control board part number 12868513 this may be the reason for the problems you are having. I am placing a link for your refrigerator below. Place the model number in the model search feature. This takes you to some models just the same as yours, just choose one. On the left of the screen click on controls. there you will see the part I mentioned. Yor freezer is also not defrosting properly also and this is most likely the control board. Let me know what you find and if you have other questions, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Maytag MBF2556HE Bottom Freezer...
Lights come on, not cooling, temp indicator shows (-)
Because your digital controls appear to be confused I think the electronic module behind the temp control is defective. The part number for your control board is 12868513
You can enter the model number JFC2087HRP in model and parts search feature at the link below. You may want to unplug refrigerator and examine the part for burn marks or other signs of damage. Let me know what you find, Thanks Sea Breeze
May 23, 2009 | Jenn-Air JFC2087HRP Side by Side...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
