Question about Electrolux Kitchen Appliances - Others
How to replace belt on prima LPR 720 - Electrolux Kitchen Appliances - Others
2 Suggested Answers
SOURCE: i need advice on how to change the drum bearings
Hi John, I saw you post on here and wonder if you still have your washing machine? I also have Prima Washer Dryer LPR720 with a problem. The belt has broken and has ripped off 2 x Orange wires and 2 x Grey wires. Do you happen to know where these should go? I would be extremely grateful for you help.
Regards
Dan
Posted on Apr 15, 2012
I have a prima LPR 450 dishwasher, the light is on but I cannot select a program
If the unit is not operating, then it will require service. To make service arrangements, you may either contact our Customer Interactive Center at 800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair
May 10, 2014 | LG LDF9810ST Built-in Dishwasher
I need advice on how to change the drum bearings on a Prima LPR 720 washer dryer. so far i have all the outer casing and the belt off
Regards
Dan
Sep 18, 2010 | Electrolux Kitchen Appliances - Others
Unable to start the oven prima lpr9023
Hi i have just fitted my new prima double oven Type FCSM9 Model LPR 9030 and the main oven will not work, and i can not set the clock. it came without instructions. can you please help
Nov 10, 2009 | Ovens
No lights on prima lpr 600 dishwasher just keeps filling up with water not draining
When there is no light at all, and machine is stuck with inlet valve open from start, then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Mar 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Continual beeping
I've had this problem a couple of times.. I filled a pan of water, poured it into the bottom, turned it on and made sure the pump was actually pumping.
I then unscrewed the dishwasher from the housing and turned off the water and electric, removed the outlet and gently rocked the dishwasher to try and dislodge anything inside the pipes.
Worked twice now anyway!
Hope this helps :)
Dec 13, 2008 | Dishwashers
Prima lpr 600
Sounds like something may be blocking the pump, causing overload -- may need a service call.
Feb 10, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Oct 17, 2007 | Dishwashers
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Kitchen Appliances - Others Logo
29 people viewed this question
Top Electrolux Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Electrolux Kitchen Appliances - Other Expert? Answer questions, earn points and help others
