Question about Stihl Chain Saws, 017, 019, 021, 023 & 025
Makita chainsaw starts and revs then dies - Stihl Chain Saws, 017, 019, 021, 023 & 025
    Problem Solver:
  • 12 Answers
Check the fuel filter in the tank is clean it could be blocked
Posted on Jan 26, 2015
I have a Makita DCS390 Chainsaw, looking for a fuel tank plug.
contact Makita or a retailer that sells them
Feb 01, 2017 | Makita Garden
Why will my ps7910 not rev up
Check the Setting marked (L) for low idle on the carburetor. Turn counter clock wise & see if that helps. If not then turn back to correct position. Don't touch (H)! If this doesn't work then then Carburetor might need to be cleaned.
Aug 12, 2014 | Makita Chainsaw Sprocket For Dolmar And...
Makita dcs6401 chainsaw stopped in use want restart
remove the muffler and see if it starts if so open the muffler and clean the screen inside
Jun 10, 2012 | Makita DCS6401 20 20",64cc Chainsaw 2...
My makita rbc420e starts ok ticks over but will not rev I think it's a fuel problem
take off the muffler and try it if ok open the muffler and clean off the screen
May 08, 2012 | Garden
Makita battery drill - batteries have charge, cleaned contacts - no action . Ideas?
Makita switches can go bad along with the electric motors inside ,I would check your battery with a volt meter then split the case and check for power going from battery to switch and forward/rev switch to motor, youmight just find a bad wire connection if you are lucky
Sep 17, 2011 | Garden
I have a makita jn1601 nibbler and I'm trying to change the punch. How do I do this?
Removing or installing the punch and die
Always replace the punch and die as a set.
To remove the punch and die, loosen the lock nut with the wrench.
Remove the die holder from the tool.
Use the hex wrench to loosen the bolts which secure the die. Remove the die
from the die holder.
Use the hex wrench to loosen the screw which secures
the punch.
Pull the punch out of the punch holder.
To install the punch and die, insert the punch into the
punch holder so that the notch in the punch faces toward
the screw.
Tighten the screw to secure the punch.
Install the die on the die holder.
Tighten the bolts to secure the die.
Then install the die holder on the tool so that the punch is
inserted through the hole in the die holder.
Tighten the lock nut to secure the die holder.
After replacing the punch and die, lubricate them with machine oil and run
tool as needed
Here is a link to a manual in case you need it to:
http://www.makita.ca/data/upload/tools/(JN1601)883894-943_75725_owner_English.pdf
Thanks for using FIXYA
Please rate us.
May 25, 2011 | Makita Garden
Makita DCS34 chainsaw After a period of use ( this varies from 15 mins to 90 mins) the saw will tick over but will not rev ( just as if it is running out of fuel) also the priming bubble sticks in when...
This could well be an issue with the fuel tank breather, when the problem occurs try quikly losening the fuel cap, if it picks up again it needs the take breather replacing
Apr 03, 2011 | Makita DCS34 Commercial Grade 14Inch 33cc...
Stihl Chain Saws, 017, 019, 021, 023 & 025 Logo
50 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
