Question about Toyota Vehicle Parts & Accessories
What is the right temperture out of vent i cab onchevy spark
    Sergeant:
  • 191 Answers
For air conditioning, at least 20 degrees below ambient tempoerature
Posted on Sep 26, 2014
What the temperture suppoe to be in the heater on a 2006 saturn ion 2 2.2L?
Check the water hoses that go to the heater core under the hood. Depending on the thermostat, your water temperature should be around 190-200 degrees.
Jan 19, 2017 | Saturn Cars & Trucks
Water coming through air vents
clean out the drain under the windscreen and ensure that the drain hoses down inside the mudguards are not blocked . ON the dash controls close the vent to recirculate the cab air and not allow fresh air into the cab.
Mar 14, 2014 | 1994 Isuzu Rodeo
02 gmc sonoma 4.3 engine starts and runs great for 30 minutes and then stalls like its flooded, if it sets after stalling for 30 minutes and cools able to drive home before starting to stall again. After...
Smell of the oil,to see if the fuel injector(spider)is leaking into the crank case,if so,the intake will have to be removed to repair the problem,oh,and change the oil.
Jul 11, 2010 | 2002 GMC Sonoma Extended Cab
Outside temperture is reading wrong
in front .....near hood latch/radiator
Oct 16, 2009 | 2004 Ford F150
This Summer Engine hesitation during warm up. Fine after warm
Your right ! The coolant temperture senser is ( bent ) Lying to the computer to the real temperture of the coolant. mixture wrong and it runs bad till warmed up. Senser is cheap and easy to install. it won't code the check engine light unless it goes plumb open or shorted and doesnt happen too much. newer cars and trucks they fixed this and the newer computers conpare the air charge temperture senser, the coolant tenperture senser, the ambiant temperture senser and the interior temperture senser and it knows how long its beenoff and the newer ones still even know that time it is and gat to know its running pattern if it has one. So it tunes its self to the finest end for your pattern and remembers it. Some thing doesn't seen right and someone of these doesnt make sense it goes on its patteren and runs just fine guessing whitch sensers to believe and which to take with a grain of salt. It does it a few times too many it remembers which senser is the lyer dis regards it and turns the check engine light on uses the rest of the good sensers to run on and goes on its merry way telling you to take me to your dealer to get another car or be fixed. They hope you'll get another car so they can soak you again fixs your old one and make a ton trashing it so the government can pay them a bonus to get you in there to keep the ecomomy moving
Aug 12, 2009 | 1995 Ford F150 Styleside Regular Cab
The problem is with the heater.
3 words come to Mind. Heater Blend Door
Mar 17, 2009 | 1999 Ford F150 Regular Cab
Heater won't heat in cab
if the inlet and outlet hoses are getting hot to the heater core then the problem is the air temperture control blend door actuator in the heating/A/C ducts, this door directs air flow either across the heater core or the AC evaporator or mixes the 2 air flows for a desired temp at the outlets, hence the name blend door, to change this part u must remove the dash assembly.
Jan 05, 2009 | 1997 Dodge Ram 1500 Club Cab
Air conditioning
I think it is going to be a vaccum leak.
Sep 14, 2008 | 2002 Ford F150 Regular Cab
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Vehicle Parts & Accessories Logo
20 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
