Epson C-3900 service code ?
What is the maintenance code to enter into the maintenance mode.
3 Suggested Answers
chazman05
  • 48 Answers
SOURCE: I NEED MANUAL FOR REPAIR EPSON STYLUS CX-3900
http://tech.epson.com.au/downloads/message.asp?platform=winxp&techtips=techtips&EmailAdd=&MetricIDReturned=2694589&submit=Search+%3E%3E&sCategory=Multi_Functional&id=styluscx3900
Copy and paste link in browser then download the user manual.
Posted on Dec 16, 2008
drifterK
  • 4924 Answers
SOURCE: i have canon ipf 6100.
try to get open the front cover to get into maintenance menu ..and reset ..or try the classic method with the power button pressed...when you reinsert the power cable ...and click on the reset 2 times to get into that menu ..
Posted on Jan 06, 2011
Service mode of kyocera fs-1120mfp
for kyocera 1820LA look if it's works:
turn on your computer by opening the top door previously.
you press the menu system.
you fit in service configuration and enter.
press the START and # then enter.
done this in configuration service runs a new submenu called maintenance mode.
until it happens you should try this.
when you enter maintenance mode out and then back.
browser to locate yourself U163 code.
you give execute.
Nov 13, 2013 | Kyocera Office Equipment & Supplies
Error code c6000 of copystar cs1815
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 20, 2011 | Kyocera COPYSTAR CS-2050 Printer
After I follow what ottoman23 said, the machine is now saying that I have error code C6000. What is this?
Purpose
Method
Completion
Mar 14, 2011 | Kyocera Copystar CS-1820 Black and White...
C6400
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine.
Enter the maintenance item number (163) using the up/down keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Turning power switch off and back on
Description
Purpose
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera Copystar CS-1820 Black and White...
Display the Call service C6400 code
Completion
Description
Purpose
Method
Completion
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
Epson aculaser c2600 error e114
This means the transfer unit has reached end of life and should be replaced.
To reset the message you must enter in a maintenance mode
Press back+up+down+enter and switch on the power.
In the maintenance mode Scroll trough to "Reset Tr counter"
Oct 15, 2010 | Epson AcuLaser 2600N Printer
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Dec 16, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Kyo 3900 printer
menu button scroll down to other than down to service than down to maintenance press enter after you fit the maintenance kit and the developer up.
Jun 25, 2008 | Kyocera FS-3900DN Laser Printer
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
67 people viewed this question
k24674
jasbo
jasbo
