Question about Plantronics Radio Communications
Plantronics CO52 headset cant hear - Plantronics Radio Communications
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: plantronics CS55. When using the wireless headset
wb91
  • 126 Answers
SOURCE: I recently purchased a plantronics
This is a common problem if you are using a 2.5mm patch cable instead of the Vista M22 amplifier. Phones do not put out enough power to the 2.5mm jack. If you are using the Vista M22 amplifier make sure the batteries are fresh and installed correctly. Also sometimes a voice tube can become clogged with debris which can restrict the airflow and people will not be able to hear you.
Good Luck from Headsets Direct!
Posted on Apr 14, 2011
wb91
  • 126 Answers
SOURCE: i connected my S11 plantronics
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Posted on Jun 03, 2011
HDI Headsets
  • 537 Answers
SOURCE: I have a Plantronics C610
Here are a couple of things you can try. I included the link for the user guide below.
Callers cannot hear me.
• Headset is muted. Press the mute button on headset to unmute the microphone.
• Headset microphone boom aligned incorrectly. Align the headset boom with your mouth.
• The USB adapter is not set as the default Voice device. Use the Voice settings in Windows under Sounds and Voice Devices to select "Plantronics C610/C620" as the voice device.
Here is a link to the Plantronics C610 User's Guide.
Good luck from Headsets Direct!
Posted on Sep 06, 2011
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Nov 07, 2011 | Plantronics S11 Headset
Plantronics Voyager Pro - Just over 1 year old, nicely charged up and matched to my NOkia 5130c. 'Suddenly, someone calls me while i am driving - cant hear them - - phone display shows connected. ...
Aye, laddy, you've done all that's humanly possible to make it work with no success (I'm a doctor, Jim, not a miracle worker!*). Yer only recourse is to get Plantronics to replace it. You mention "just over 1 year old." If yer within 12-13 months, call Plantronics at 800-544-4660 x5 x5538 for warranty replacement.
Oct 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
My Plantronics Voyager 520 seems to be stuck in mute. I can hear others, but they cant hear me.
Try deleting the headset out of your phone and then re-pair it back up and see if that corrects the problem.
How to Pair the Plantronics 520 Headset
Jun 27, 2011 | Plantronics Hama Voyager 520 Bluetooth...
I have a Plantronics C610 headset. The caller can hear me, but I can not hear the caller.
Jun 16, 2011 | Plantronics Blackwire C610 Headset
I hooked it up to my ps3 but i can't hear any volume from the game. i ahve an adapter. the mic works but i just can't hear anything
Per Plantronics the Gamecom 367 headset is not compatible with the ps3. Plantronics did say the Gamecom 777 will work with the ps3. Please see the link below for the Gamecom 777.
Plantronics Gamecom 777
Apr 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
When I plug in in my plantronics 367 closed ear gaming headset all I hear is the sound I cant get the mic working
This is a plug-n-play headset, so no special software is necessary for it to work properly. You want to make sure the leads are plugged into the right jacks on the computer and that the jacks are live.
Apr 18, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Cant hear my headset for ps3
On your ps3, go to accessory settings, then sound settings. Make sure the output device is the same as the input device, ie. your headset.
Hope i helped :)
Aug 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Radio Communications Logo
57 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
