Question about Xitel Pro HiFi-Link External Sound System
Xitel pro hifi link windows 8 - Xitel Pro HiFi-Link External Sound System
Is there an upgrade for Xitel Inport for windows 10
Yes. V11.1 of LP Recorder is supported on Windows 10 with Xitel's INport. There are instructions on how to configure Windows 10 to use it here:
http://www.cfbsoftware.com/Windows10/INport.htm
Sep 26, 2016 | Xitel INport Deluxe
I now have a windows 8 how can I get it to work?
Have a look at the original instructions to see which operating system the software will work with. It should also tell you on the installation disc. If it doesn't mention Windows 8 you might have a problem. You can also visit the Microsoft website to see if your version will work with Windows 8. Or go to the help screen on windows and type "software won't run in windows 8".
You can also visit the software makers website to see if they have a solution.
Jan 29, 2014 | Xitel INport Deluxe for PC
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
Windows 8 is not compatible with the Xitel versions of LP Recorder. Xitel customers are eligible for a discounted upgrade to the latest CFB Software version of LP Recorder:
http://www.cfbsoftware.com/shared/upgrade.aspx
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I have an Xitel Hi-Fi link, USB type. For some reason it stopped working on my Dell Windows 7 machine. When I check the device manager is shows it with a yellow icon and says it's not working....
The product details say that is a plug and play device, this means it shouldn't need a driver, how ever with it being used with windows 7, I don't know if that makes the difference. Shouldn't, but never no, I also had no luck finding drivers. I would uninstall the drivers associated with it and reboot your computer with this hooked up and see what happens.
Jun 10, 2011 | Xitel Pro HiFi-Link External Sound System
I need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Apr 08, 2011 | Xitel INport (HFLI1X1) Audio Input
All drivers for hp pavillion dv6602au
if you need dv 6602 au xp audio driver you search audio driver version 3.26.0.50 http://www.megaupload.com/?d=G2EXH24B
Dec 13, 2008 | Xitel Pro HiFi-Link Sound Card
Xitel Pro HiFi-Link External Sound System Logo
Top Xitel Computers & Internet Experts
KG John Justin
KG John Justin
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
