Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Channel up down feature doesn't work anymore - Sony FD Trinitron WEGA KV-32FS100 32" TV
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Channel selector doesn't work
If only 1 button does not work it may be a problem where some liquid got inside--
Some units have a lockout feature which will disable most or all buttons on the remote and or the set.
If set changes channels with the buttons on the set problem is with the remote--they can be tested easily.
Apr 15, 2012 | Samsung Bn59-00996a Remote Control
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
Dear Sir, We have MorphoSmartTM 1300 Finger scanner which was working in Windows XP. But we changed the server OS to Windows 7 and the scanner is not working anymore. Do you have a driver for Windows...
A windows 7 driver doesn't exist yet.  However, you may be able to run it with the old drivers by using the compatibilty feature.  Let's hope so.  Here's a link with directions.  http://www.sevenforums.com/tutorials/316-compatibility-mode.html
May 10, 2011 | Computers & Internet
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Q2770 problem
search on its manual if if has a LOCK feature! if it is lock then it would be fixed on a single channel. Lock feature was designed to prevent children from playing with your TV channels and volume and everything on the remote!
Nov 17, 2007 | Prima CV2011 TV
Forgot v-chip code
Sharp has several locking and V-chip commands but one of these three possibilities should work.
Newer Combos With "Time Limiter" Feature
If the "Secret Number" is forgotten, simultaneously press the STOP, RESET, and VOL up buttons on the front panel of the set.
This disables both the "Channel Lock" and the "Time Limiter" features.
CTV's Lock Mode---Blue screen and display says,Parental Control Rating Unknown
Try This: Hold Channel up and down on the set while pluging in AC cord.
Or Try This: On the set, press volume up and channel down at the same time.
CTV's V-Chip Release
When screen asks you to "input secret number" press and hold channel up and down on the TV set until message disappears. Press menu 2 times to exit.
Hope this helps!
Bill
Nov 13, 2007 | Sharp 25R-S100 25" TV
SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Aug 20, 2007 | Broksonic CTGV-5463TCT TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
