Question about JVC XV-N322 DVD Player
Vhs tape won't play vcr/dvd combo shuts off
I have a jvc vhs/dvd combo player, and the vhs tape wasn't going in, I lightly pushed the tape into the machine and then machine automatically turns off. It's not reading the tape at all. I've taken the top off of the machine and nothing is jammed, but the mechanism that loads the tape definitely is not working properly. Any advice?
5 Suggested Answers
shadow5599
  • 51 Answers
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
SOURCE: Have the JVC HR-XVC26U. I installed this vhs/dvd
Posted on Jun 24, 2009
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
The DVD part of the machine keeps skipping and now just won't play any DVD's.
I push the VHS Cartridge in, it drops down to the play position, the front door opens, the tape comes out, it goes around the chrome wheel that is spinning, but it will not play, will not rewind, will not fast forward. It then shows "Error" and the machine shuts off, with the tape still around the chrome wheel, When I turn the machine back on, the VHS Cartridge ejects from the machine. This machine has been used very little, I loaned it to my Son In Law and it came back with the VHS Tape Deck not playing. I have the machine open, so I can see what it is doing.
Dec 11, 2010 | GoVideo Go Video DVD/VCR Combo
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Mar 02, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Oct 18, 2007 | JVC HR-XVC19S DVD Player/VCR
JVC XV-N322 DVD Player Logo
265 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
