Question about Haier 3.5 cu. ft. Chest Freezer HNCM035E
3.5 Haier chest freezer leaking underneath
Leaks under the freezer. Drain plug is tight, light shows unit is on and compressor working.
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
SOURCE: haier freezer hcm050La comes on then shutdown
could be overload, and relay , but more chance the compressor is drawing excess amps and needs replacing
Posted on Nov 26, 2008
bobicehouse
  • 1524 Answers
SOURCE: Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Posted on Jul 30, 2010
walterkunesk
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
  • 12 Answers
SOURCE: Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Posted on Dec 18, 2011
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
My Haier Chest Freezer started releasing water from underneath. It´s 2 years old
A Freezer usually has a condensor drain coming out of the compressor, that empties into a condensation dish underneeth, where condensation water is picked up and Re-evaporated.
It is most likely that your Drain is clogged.
Happened to me.
Have someone check your Drain, and if needed unclog it with a small prying tool into the tube.
Sep 21, 2016 | Haier Freezers
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Apr 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer leaking and icing underneath
The plug may have been mashed and deformed.
Replace it.
Mar 12, 2009 | Kenmore Freezers
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Haier freezer hcm050La comes on then shutdown
Nov 25, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Haier 3.5 cu. ft. Chest Freezer HNCM035E Logo
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
christian nielsen
jdthefixer
Are you a Haier Freezer Expert? Answer questions, earn points and help others
