Question about HP P2055DN LaserJet Monochrome Printer
49 err 3D910C8
Printer will not print. it only says this error message and to turn printer off and back on, but it still will not print.
3 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: Hello, I have problem with hp
Go to hp.com.
Download and install the latest firmware.
The instructions are given there.
Posted on Sep 21, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: i got and error message on my printer hp p2055dn
You probably are printing with a newer version of adobe and have not upgraded the firmware on the printer. Go here and download the firmware update utility, first option for upgrades on the page. Once downloaded run this utility and it will ensure that your firmware is up to date. If you cannot get the printer to come to ready, you will need to clear any print jobs that are in the queue waiting to print first.
Posted on Apr 08, 2011
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
I have PH Laserjet P2055 printer 49 err 4810E9E
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
May 30, 2012 | HP P2055DN LaserJet Monochrome Printer
" 49.FF04 Error Turn off
Critical firmware error. Can be caused by invalid print commands, corrupt data, invalid operations or even electrical noise in the cable.
Turn off the printer, then turn it on.
Press Stop to clear the print job from memory.
Turn off and back on.
Print a document from a different software program.
If that document prints, go back to the first program that failed and print a different file.
If the error comes back, that file is corrupt.
If the message persists with different programs and print jobs have the formatter replaced.
Apr 16, 2011 | HP LaserJet P4014n Printer
I got and error message on my printer hp p2055dn 49 err 6400444 turn off then turn on
Apr 07, 2011 | HP P2055DN LaserJet Monochrome Printer
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on. Change the network cable but no use
Had the same error. Turned out the pdf I wanted to print had an empty page. When I removed it, the error disappeared and I could print the document.
Mar 13, 2011 | HP P2055DN LaserJet Monochrome Printer
Error code 49.FF01 can't turn on or off
A firmware error occurred ( This error is usually caused by a bad formatter board)
SOLUTION
Feb 22, 2011 | HP LaserJet 4250tn Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Hello, I have problem with hp Laser Jet P2055dn, It appear 49 Err 3D910C8. Cannot print. Kindly assist. TQ
Go to hp.com.
Sep 21, 2010 | HP Office Equipment & Supplies
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
HP P2055DN LaserJet Monochrome Printer Logo
506 people viewed this question
Seeker5211
Seeker5211
