Hooking dvd player
Trying to hook up dvd player to old tube tv attatched color coded wires and it don't work
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
If i remember right the older tv had to be on channel 3. hope this helps
Posted on Apr 17, 2014
pishta68
  • 593 Answers
SOURCE: hooking it up
Easy, just match up color codes from tv to dvd player. If you only have red, yellow and white, they should coincide wih the TV as some TV's dont have the 5 color jacks R/W/G/B/Y inputs. If they do, use the colorstream or "comp" input on the TV
Posted on Mar 03, 2008
SOURCE: hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Posted on Apr 13, 2008
rroath49
  • 35 Answers
SOURCE: DVD player will not show in color.
could be loose or damaged SVideo cable or cable getting interferance from other equipment. try moving cable around and see if color comes back.
Posted on Jul 30, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
  • 11 Answers
SOURCE: hook dvd to tv with direct tv dvr
does your dvr have componet video connections
Posted on Jun 01, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How to hook up wires from dvd to tv, what is the order
Your tv and DVDs have color coded wires white,yellow and red..just mscth them..most have words like video or audio out and in...would be out to TV on the DVD in on the TV pretty much self explaining..good luck
Oct 05, 2014 | Sungale DVD-2026 DVD Player
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
How to hook up my dvd player
ya its easy there are 3 wires yellow for video & red - white for audio just plug that wires in the same color socket from tv to player
Jun 12, 2010 | Hitachi DV-P745U DVD Player
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
I have a samsung 32 inch LCD HDTV and trying to hook up to Pioneer DVD player. There are three colors of wires to connect the DVD to the TV. I get the sound(audio) but not the video. It just shows black...
Just make sure you hook up the wires to the correct plugs. They should be colr coded - red and white for audio and yellow for video. The sockets on the TV will have the same color code. If not, its just a matter of trying various combinations. If nothing works, then try using a different cable.
Sep 26, 2008 | Televison & Video
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
