Question about Bose SoundDock Digital Music System for Apple iPod - White
The volume blasts when trying to turn it up or goes completely off when trying to turn it down
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
No low volume
known bug electrolytic capacitor+eeprom store, remove power+batteries and store min 1 week without power!!
Dec 03, 2011 | Sangean ATS 909 AM/FM/SW Radio
Amplifier shuts off or goes full blast
That a new one for me, it just goes full blast huh? I don't have an answer for that, but your amp can shut off because of a lot of reasons.
One you might not have enough power running to this amp. Check to make sure your amp gain is not turned all the way up, this is NOT the volume for the amp. It's to get your amp and the head unit on the same page (i.e. if the radios at 50% volume and so is the amp) if you turn it down too low that will make the amp very sensitive to volume adjustments, and your amp will be at 100% while the raidos at like 50 or 75%. And once you go past the 50 or 75 on the radio the amp, it's going to keep trying to play higher even though its already maxing out which is going to cause it to clip and cause distortion untill it goes into protect mode. Common mistake with a lot of people.
Two you might check all your wire connection to the amp. Three internal damage. The list can go on and on as you can see. RCAs might be damage or even your remote wire. Upgrading your alternater and battery can help.
Some people would even say to check your car factory amp (some times in the trunk or in between body panels) to see if it is bypassed. If it is not bypassed it could be a posability to shut down the other amp caused by to much power causing it to shut down. hope this was helpful
May 12, 2010 | AudioBahn A1500HCT Car Audio Amplifier
I cant turn down my sound when i do it automatically goes to full blast it is making me very angry
Not enough information. Is it a software problem or a hardware problem? If it is a software problem the solution is simple. Don't try to adjust the volume inside windows. Just use the volume knob of your speakers to do that.
Nov 10, 2009 | Microsoft Windows Vista Ultimate Edition
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
My radio volume goes from full normal to full blast when it wants. I have to turn it off to save my speakers.
I would replace the radio. Especially if its stock. Look on www.craigslist.com and www.ebay.com for a replacement. You should get a good deal between the two.
May 08, 2009 | 1995 Dodge Ram
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Volume goes full blast when turned up from zero to just a "1" onscreen
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Jan 25, 2008 | Toshiba 19A26 19" TV
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
Bose SoundDock Digital Music System for Apple iPod - White Logo
27 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
