Question about Treadmill Doctor Freespirit Cardio Cross Trainer 800 Resistance Motor
My free spirit cardio crosstrainer 800 has high resistance
The elliptical displays high resistance when I try to work out..even with out a power supply
Do you know where i can buy the console?
Its very unlikely that its the console, however if you still would like to buy it you can try sears canada
Jun 13, 2014 | Treadmill Doctor Freespirit Cardio Cross...
Do you know where i can buy a new console for Freespirit 110?
Sears sell the Free spirit product and should be able to supply parts.
What is the power source for the display console of a proform 650 cardio crosstrainer elliptical? The display on mine is not on.
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual
God bless you
Nov 01, 2013 | Proform 650 Crosstrainer Treadmill
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
I have a Free Spirit Cardio Cross Trainer 800 by Reflex Step . The display is for programming and set up is blanked . I think I have to replace a battery or to plug in for power . I do not have a...
I have the same machine. There are 4 D cell batteries in a small drawer at the bottom of the console. The screw is located on the left hand side and is a bit awkward to get at. The drawer slides down from the middle of the console.
Jan 18, 2011 | Exercise & Fitness
I have a Pro-form 650 Cardio CrossTrainer. All of the information on the display is displayed correctly but the resistance seems to be too high on level 1 and the resistance knob is difficult to turn once...
Normailly there are 2 system:
1) Manual, see the belt if there are defective,try to put a Little LUBE it,since has a LOT of mechanical stress. Replace it if Necessary.
2) The small motor in the system, can be faulty or broken, replace it.However test the batteries if the system have, clean the contacts batterys, with special liquid clean contacts cleaner, and tight very well the connector, and clean too.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Proform 650 Crosstrainer Treadmill
Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Treadmill Doctor Freespirit Cardio Cross Trainer 800 Resistance Motor Logo
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
