Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
How to put automix piston back in place of a Bissell Power Steame
Took the top off to clean and the automix piston fell out. Need to know the position so that the solution knob catches hold of the piston. Please help. I love my steam cleaner..
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Posted on Jun 19, 2009
Reassambly bissell 8910
I am in the same situation with my 8910 if you get an answer will you let me know my email is codeman750@msn.com
Aug 09, 2009 | Bissell 8910 ProHeat Clear View Upright...
Automix knob and piston problem.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
45we
Jan 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The solution in my smart mix will not mix with water and the button just keeps going round and clicks and will not stop on either water or solution.
The smart mix knob is connected to a piston that slides up and down into the automix assembly. This piston has come off of the smartmix knob and left the unit on water only setting. Sometimes the smart mix knob breaks on the bottom side letting loose the piston.
This can be a difficult repair. You have to unscrew the flow indicator window and remove the fan and screen(pay attention to how they come out, most people want to put the pointed end of the white screen down. It goes up.) Place a piece of 2X4, a book, something underneath the machine, between the rear wheels. This will lift the wheels into the air, and keep everything in place when you remove the hood. Take the 6 screws out that hold the hood and lens. As you remove the hood try to do it slowly and pay special attention to any hoses that might try to pull off with it. If you don't get those hoses back into the right place, the machine will not work. The piston will probably be stuck into the automix assembly when you get the hood off. It is a three inch black cylinder with an O ring on it. If you hold the hood upside down and place the cornered side of the piston into the corner of the housing between the knob and the solution chamber, you should be able to hook the winding on the knob with the piston and then turn the knob to screw the piston down into the windings. It won't lock into place, but hold it there well enough to put the machine back together correctly.
If you feel like you're forcing something when putting the hood back on, you probably are, so stop and check to make sure all the hoses are where they are supposed to be.
Good Luck
Nov 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901 proheat solution wont mix
Good Luck
MOD 1699-f reassemble cleaner fluid mix switch
This is one of the most difficult machines to work on, but I can help you to reassemble the the "Automix Assembly." There is a black piston with an O ring on it that has to be put in place before the hood is put back on. This part will actually set inside the windings on the smart mix knob, before the hood is placed on the machine, and as you place it on the machine, the piston will have to slide down in the hole on the automix. Getting the piston into the windings can be a little tricky. You might have to play with it a bit and it doesn't lock into place. It just sits in there loosely, just enought to hold it in place while you put the unit back together. It's hard to describe how to place the piston in the windings of the knob, but I'll give it a try. Hold the hood upside down and place the squared corner of the piston into the squared corner of the hood between the knob and where the solution tank would sit on the opposite side. Now you can turn the know and screw the piston down into positon and the hood is ready to install.
Hit: put a book or peice of 2X4 under the unit between the rear wheels to lift the wheels off the work surface and help line everything up. If the hood doesn't feel like it is seating into place correctly, something is wrong. Very important on this machine: if even one hose is slightly out of place it with not pump. If it doesn't pump alway check the attachments to see if they pump. It they don't, then you might have a clogged heater.
Good Luck
Nov 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699-1 reassmble
I FIGURED IT OUT!!!!YAY.
the piston comes out easily with a pair of plyers.hold the cover on your lap upside down, smart mix knob closest to you,there is a slot for the piston to fit in to, turn the knob slightly (about 1/2") you will see that you can lift the knob slightly out of the way then you can slide the piston into place. leave the knob at that position to hold the piston and slowly put the cover back in place. if the piston goes in,just before you put the cover all the way down turn the knob back to water only.if everything is in place, PUT THE SCREWS IN!!!! hope this helps.
Jul 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat
The piston needs to be on the bottom of the smart mix valve, and the knob needs to be in the water position when you put the top cover back in place.
Jul 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell doesn't work with cover on...
Did you put the piston on the bottom side of the smart mix knob? If not, put it on, then turn it slightly so it won't fall off. Just before putting the top cover on, put the smart mix knob in the water only spot, then push the top on and make sure that the knob turns back and forth ok. Secure the top down, and put the flow indicator on. Sometimes when you over tighten that cap, it doesn't want to spray right. So just snug it. If you haven't pinched any lines on the base or inside the handle, it should work. Could also be that the flow indictor cap is bad. MAke sure the gasket at the bottom of the tank is on the valve and not sitting in the hole.
May 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
MY BISSELL DOES NOT WORK
When you put the top back on, did the piston line up and go into the hole? The piston mounts on the smart mix knob from the bottom, just before the top is on, put the smart mix knob in the water only setting, then push the top down. You could also have pinched a line if any of them aren't in the right place.
Mar 17, 2008 | Vacuums
Smart mix plunger bissell 1699
Check your wiring. I have a photo of the correct wiring if you'd like it for reference,
Oct 02, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
526 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
