Question about Whirlpool RBS305PR Electric Single Oven
Aftr using self clean my rsb305pr whirlpool oven will not heat, self clean ran fine an completed normally.
Help
SOURCE: Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Posted on Aug 25, 2007
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 59 Answers
SOURCE: self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Posted on Apr 27, 2009
  • 41 Answers
SOURCE: oven won't heat
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I used the self cleaning option and cleaned the oven now that the cleaning process is complete the oven will not heat up. the clock/timer just above the oven door works but it will not heat up at all. What...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
After using self clean oven will not heat on any setting
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 17, 2009 | Whirlpool RBS275PD Electric Single Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Whirlpool RBS305PR Electric Single Oven Logo
14 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
