Question about Vacuums
Install valve spring stem kit for Solution Tank for Hoover Steam Vac F6028-900
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Valve Stem Assembly for Hoover Steam Vac
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Posted on Feb 14, 2008
reddevil6
  • 1673 Answers
SOURCE: valve stem assembly
  • 37 Answers
SOURCE: hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Posted on Sep 24, 2008
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
Jun 19, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
I HAVE A HOOVER STEAM CLEANER MODEL#F5881-900 THE SOAP LEVER HAS NO TENTION,SOMETHING BROKE BUT DONT KNOW WHAT!
The valve at the bottom of the tank has a valve stem and spring, you may have to replace the spring maybe.
Go to http://vacuumsuperstore.com/F5880.html for a picture.
Jul 13, 2008 | Hoover Vacuums
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Dec 29, 2007 | Vacuums
Valve stem assembly
Vacuums Logo
358 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
