Question about Gestetner - 5309L CopyPrinter Copier
Getting meter reading for gestetner 5309l - Gestetner - 5309L CopyPrinter Copier
2 Suggested Answers
SOURCE: Where is the plotter cover on the gestetner
The plotter cover is the piece that you press down when installing a new roll of masters. it is located on the top right of the machine.
Posted on May 27, 2009
E22 code
E - 22 Scanner home position sensor error.Possible causes:
scanner home position sensor failure
scanner motor defective
incorrect scanner ddrive wire position
Remove the exposure glass and verify the wire and the sensor actuator.
Turn DIP switch 101 - 1 ON and press START key to run free the scanner.DIP switch is located on PWB board in rear area,remove the rear cover.
Feb 07, 2013 | Gestetner - 5309L CopyPrinter Copier
Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
Nov 11, 2009 | Gestetner DSm645 Digital Imaging System
Gestetner DSm618d accidentally adjusted display too dark, now can't read it, so I can't control the machine, nor can I readjust ''contrast'' Vince
No matter how dark the contrast, if the room is dark you will be able to read it well enough to get to the settings -that is unless the display is burned out altogether
Oct 23, 2009 | Gestetner DSm618d Copier
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Sep 24, 2009 | Gestetner Office Equipment & Supplies
Gestetner DSM616 no network config
Sounds like you don't have a print or print/scan option in stalled. All machines come with network port but only works if option is intalled. You can check if you have the option installed, maybe just not activated. At the back just abouve the network port there is a cover that covers 2 sd card slots. If the is no sd card installed you will not be able to print to the machine. If the is a sd card installed contact me again and i will help with activation
Mar 24, 2009 | Gestetner DSm616 Printer
Sep 04, 2008 | Gestetner - 5309L CopyPrinter Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
27 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
