Question about Kodak SCANNERS ScanMate i940 Sheetfed Scanner. SCANMATE I940 CLR 600DPI 32BIT 64BIT USB 2.0 8.5X60 20PG ADF. USB
Scanmate i940 won't scan - Kodak SCANNERS ScanMate i940 Sheetfed Scanner. SCANMATE I940 CLR 600DPI 32BIT 64BIT USB 2.0 8.5X60 20PG ADF. USB
After I start, what causes error E12?
Hello
You can check the following:
1. The second scan image interface cable
2. The second scan image
Which is usually the interface cable fault
Jun 11, 2015 | Kodak Scanmate I1120 Scanner
Software disc for i940 scanner
The driver and smart touch are on the web the other bundled software your out of luck
SCANMATE i940 Scanner Support Drivers Downloads Kodak Alaris Kodak...
Jun 23, 2014 | Kodak Office Equipment & Supplies
Kodak scan mate i1120 not connecting to outlook
Don't use outlook to acquire images. Use Smart Touch. Within Smart Touch you can call a program like Outlook to open and accept a scanned document. Read the user guide for Smart Touch. http://graphics.kodak.com/docimaging/us/en/support_center/index.htm
Mar 06, 2014 | Kodak ScanMate i1120 Flatbed Scanner
Mac kodak scanmate i1120
I am assuming you are inquiring about MAC drivers for the i1120? Not happening.
Jan 24, 2014 | Kodak ScanMate i1120 Flatbed Scanner
How do i reset motorola i940
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 08, 2012 | Motorola Mobility I940 Nextel Boost Mobile...
I have a motorola i940 for nextel but was unlock for boost but I am unable to send messages but I can recieve them how can I fix that?
i believe ican unlock texting out feature for boost the new i686 brutes did the same thing and i obtained software to unlock the brutes to text out and it only takes a minute to do contact me if you like to have it done i will do for free just to see if it works my name is Jerry my direct connect is 165*507524*6 if you have this phone i know you can direct connect me and my software comes directly from iden so i really believe it will work i have been unlocking the i686 brutes for over a year now and once unlocked its permanent if you stuck even a nextel sim in that phone it wouldn't text out till you married the phone to the imei and boost says it is not there phone and wouldn't do it for anyone so if anyone out there has boost sims and wants an unlocked texting out brute i686 i have brand new phones or send me your phones and i will unlock them just direct connect me and i will do it .I do live in Md so if you want to bring me your phone you can do that also or i can meet within reason and do it on my laptop.Jerry
Jun 13, 2012 | Motorola Mobility I940 Nextel Boost Mobile...
Trying to set-up a Kodak Scanmate i1120 Scanner on a notebook with Windows 7 Professional 64 bit Downloaded and installed "InstallSoftware_i1100v1100_v1.11.exe" When I try to run "Scan...
You need to uninstall old driver then reinstall new driver from below link. Click here Click on above link download driver for your os uninstall old driver and all usb drivers from device manager then install driver. Make sure there is not any incompatible usb drivers in computer. Let me know if you need further assistance. Thanks for using FixYa.
Jun 21, 2011 | Kodak ScanMate i1120 Flatbed Scanner
Support for ScanMate/256 Window XP
Hi valposp
Please refer the following link
http://www.givemefile.net/drivers/scaners/genius/scanmate_256a.html
Hope this will help you.
Regards
TDCL
Jan 29, 2011 | Computers & Internet
How to install kodak i 1220 flatbed.
1st You download Scanner Driver. Kodak Scanner Driver After this install the Scanner driver in the system.
Installation of Scanner Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or scanner device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 03, 2010 | Kodak ScanMate i1120 Flatbed Scanner
Kodak SCANNERS ScanMate i940 Sheetfed Scanner. SCANMATE I940 CLR 600DPI 32BIT 64BIT USB 2.0 8.5X60 20PG ADF. USB Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
