Question about Harman Kardon Televison & Video
Problems & Solutions for Harman Kardon blu ray player won t read disc
Won't play Blu-ray Discs it previously played
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
Posted on May 06, 2012
My harman kardon player will read blurays, however it wont read dvds. Any idea why?
More than likely the lens that read dvd discs has failed. On blu-ray players, there are two (2) optical lens. One reads blu-rays and the other dvd/cds. They are independent of one another.
Nov 26, 2014 | JBL Harman Kardon Bds 2 2.1 Blu-ray Home...
Pioneer bdp 440 won't play region A blu ray
It may be the encoder that is going faulty in the unit i had the same problem with my dvd player after using different regional discs in them.
Feb 21, 2013 | Pioneer BDP-440 Blu-ray 3D Code Free DVD...
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
My blu ray player won't play the hunger games
Need more info. Does the player accept the disc? If so, do you hear the disc spinning inside? If not, what does the player do? Does it kick the disc back out? Will this player accept and play other discs?
Sep 10, 2012 | Sharp Aquos Bd-hp22u 1080p Blu-ray Disc...
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
May 06, 2012 | Sharp Televison & Video
Won,t play latest discs
In most cases, the issue might be with the Java content on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc including the previous played ones, then it may require service.
Feb 25, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
48 people viewed this question
Top Harman Kardon Televison & Video Experts
Electro Med Services...
hims Patel
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
