Question about KitchenAid KSRA25CNSS Side by Side Refrigerator
Kenmore cold spot model number 106.9552850 type c22ssa95
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
Everything is working but fan in frezer everything in bottom not getting cold it is a o5 model the name is kenmore cold spot model #106.74254400 type 22tfa
If understand your problem as being a bad fan in the freezer. Take the plastic or metal panel off that covers the back of the freezer. Inside you will see a fan that is held on by two or 3 screws 10mm or 5/16. Unplug the wires to the fan and remove the screws. This is an easy fix just make sure you unplug your fridge first. Hope this helps you.
Aug 18, 2010 | Kenmore Refrigerators
Water will not flow. It is a kenmore cold spot
Most likely the dual water control valve is not opening to allow the water to the dispenser if that is your meaning. Now if you mean water for both dispenser and ice maker then that would change everything. See if you can locate the model number that Sears puts on the door frame near floor. The fresh food section door at base and the number will look like this example 312.256489 With that number I can see everything your side by side came with and tell you the parts and locations. You also can have someone test voltage going to the water control valves while someone presses the dispense water switch. And with a voltage meter set to OHM's test the coils on the dual water control valves for resistance and if one has a very different number that can tell you. So we have several things to look for, water supply, dual water control, (if one works and other will not) and model number, Let me know what you find, Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side cold spot 4 years old just stopped cooling and freezing
Defrost problem is possibly the reason. I need to know the model number for example 213.25897 would be a way that Sears identifies their appliances. Let me know which model and we will go from there. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | Kenmore 50522 / 50524 Side by Side...
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Lost freezer key
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
Mar 23, 2009 | Kenmore Freezers
KitchenAid KSRA25CNSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
