Question about Pool & Spa
Control panel wont shut off
Pump will not shut off
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Intire fuel system shut down put new fuel pump on it wont come on injecters wont fire either shut off switch is on
On those trucks there is a Fuel system safety switch. Usually under the kick panel of the passenger's seat.
Apr 03, 2011 | 1993 Ford Ranger SuperCab
F250 FUEL PUMP SHUT OFF
Should be located on passenger side of dash, kick panel under dash on right side. Sit in passenger seat it will be next to your right foot you will have to look at the top of the kick panel if its not equip with a hole. Just push down on the white button.
Apr 22, 2009 | Ford F-250 Cars & Trucks
1989 cougar wont start
Is the inertia switch on the passenger kick panel popped?
Jan 09, 2009 | 1989 Mercury Cougar
Pump won't shut off
Hi Shamin,
You have to replace the printed circuit card.
Mar 30, 2007 | Saeco Magic De Luxe Espresso Machine
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
