Question about GE GSS20IEP Side by Side Refrigerator
Freezer is not cold and refrigerator temp is too warm
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 227 Answers
SOURCE: Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Posted on Jul 06, 2009
  • 942 Answers
SOURCE: freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Posted on Jul 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: How cold should the refrigerator be?
38 to 42 degrees F The problem with the defrost will need to be fixed and you can check a few things that may save you the cost of someone coming out. Unplug and remove the rear panel in back of the freezer. Defrost with a hair dryer and try to get as much ice out as possible so you can have a look at the defrost heater. Yours is made with a glass tube on the outside of the heating element and if burned out you need to replace both it and the defrost thermostat that it goes through. Hopefully you will try to use my assistance and we can resolve this quickly. Now if you do not see a problem with the defrost heater let me know. Your model has a mother control board and we may need to have a look at it also. Let me know, Thank You Sea Breeze
Posted on Aug 16, 2009
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
GE GSS20IEP Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
