Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
HOW IN THE WORLD DO i GET THE FRONT OFF MY SAMSUNG WF219ANW/XAA WASHER?
Washer will only drain out the front and the pump works but wont drain out the hose! I want to check for debris in the hose etc but cant figure out how in heck to get the front off to get to the hoses and pump.
  • 327 Answers
SOURCE: Samsung washer front load willnot rinse - no water
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
Posted on May 31, 2010
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Posted on Jun 21, 2010
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
SOURCE: How do I replace the oring gasket on a front
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Posted on Feb 12, 2011
SOURCE: I have a samsung wf203anw
Posting a problem with your POS Samsung washer here is a waste of time! UII currently have the same problem a lot are having with this not draining nd code and I AM NOT going to pay for a tech to tell me that I have to have a guy come in to take my washer apart. I will do it myself!
Posted on Feb 28, 2011
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
Hello i have a samsung washer model# WF306BHW/XAA and will not drain the water i check the pump and is clean and it works ! what cut be wrong?
if the pump is clean and the motor works,it could be a blockage in the outlet pipe or the impeler in the pump is damaged,make sure there is some water in the machine, take the end of the oulet pipe and hold it over a bowl of some description if theres no blockage water should cone out of the pipe.if do not then its blocked,if it does then the pump is probably damaged.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
My Samsung WF218ANW/XAA front load washer will not drain & the display reads "nd". I have already drained the water through the front panel tube & have cleaned that filter, washer still...
Jan 22, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
Aug 11, 2010 | Samsung WF337AA Front Load Washer
Brand new Samsung wf219anw/xaa model, when going through the spin cycle it sounds like a helicopter landing and it walks, I only put in 5 pairs of jeans or towles. A tech came and said that is a normal...
I assume that the shipping screws were removed before using.
If they were, then make sure washer is level at all points.
The load you refer too, could well have gone out of balance, and this could cause it to move..
If noise still persists, then I would call them back again.
Hope this helps.
Jan 12, 2010 | Samsung Washing Machines
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
