Question about Reebok Exercise & Fitness
How do you lube the deck belt
Squeeking when walking on treadmill. When my foot contacts the belt each side squeeks. The left more than the right.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Use a good silicon spray. it goes under the belt between the belt and walking deck. apply in a "s " pattern to cover entire area of walking belt.this keeps the friction down and squeaking noises
Posted on Apr 20, 2014
5 Suggested Answers
  • 16 Answers
SOURCE: treadmill noise
If it is a chirping noise it will be the mylar sheet under your walking belt. You will need it replaced after that kind of damage. If it is an actual grinding noise it will be something else.
Posted on Apr 14, 2009
erpaalai
  • 999 Answers
SOURCE: Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Posted on Aug 11, 2009
  • 34 Answers
SOURCE: On my Sears ProForm 730 treadmill, I cannot make
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Posted on Aug 18, 2010
  • 11 Answers
SOURCE: Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Posted on Feb 09, 2011
How do you get the track to stop squeeking?
when was the last time you lube the walking belt
Jan 28, 2015 | Proform Walking Belt For The 520x...
How do I lubricate the walking belt ?
Video about How to Lubricate a Treadmill using Liquid Lube
  • This video will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine; let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video Video about How to Wax a Treadmill Using Powder Wax
  • Our video demonstrates how to properly wax your treadmill belt and deck. This video will be about applying the powder wax.
  • To properly lubricate or wax your belt and deck you will first need to clean between the deck and belt to remove any contaminants.
  • To do so, begin by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt and deck has been cleaned; Open your wax bag and using approximately a teaspoon, place the wax on the deck as seen in the video. Now repeat the process on the opposite side. Be sure to wipe up any excess wax as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the wax out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously. Remember to tighten only half way on each side then repeat the process.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to wax a treadmill using the powder wax.
How to Wax Treadmill Using Powder Wax Video
Dec 07, 2014 | Exercise & Fitness
How to lubricate a precor treadmill belt?
About This Video
  • This vidoe will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • This concludes todays demonstration of how to lubricate a treadmill using the liquid lube.
Apr 30, 2014 | Precor 9.21 Treadmill
Reebok RBTL18911 squeeks when walking or running. Left side is more than the right side.
I would check manual, it may need to be oiled or cleaned. You can always call tech support for help
Apr 16, 2014 | Horizon Exercise & Fitness
Treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Jul 18, 2012 | Reebok Exercise & Fitness
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
My roger black treadmill keeps tripping the eletric
This could be a lubrication issue if this treadmill has never been serviced or worn belt/ deck. The last thing I am thinking about is if the unit is turned on with nobody on the unit and trips the the breaker then you have a shorted lower board.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
4. Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. Do not put any lubricant on any surface with which your feet make contact. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric. 5. Adjust belt tension and centering following your owner’s manual instructions if you have loosened the belt to clean. LOOSENING THE WALKING BELT IS NOT NECESSARY JUST TO APPLY THE LUBE. Start the treadmill at 2-3 mph and allow to run for 5 minutes without walking on the treadmill. Check centering carefully and adjust as needed following your owner’s manual instructions. Using your treadmill’s handrails and safety switch for safety and support, walk on the treadmill at 2-3 mph. CAUTION!!! BELT MAY HESISTATE. THIS CAN CREATE AN INJURY IF BELT IS NOT PROPERLY TENSIONED! Within 5 minutes the lube will be preliminarily walked in to the backing of the belt. Damage and/or injury may occur if the belt is not properly centered and tensioned by using your owner’s manual. 5. CAUTION: Do not run on the treadmill until your are certain the belt tension and centering is correct according to your owner’s manual specifications. Make certain that there are no friction.
Go on E-Bay you may purchase a kit or a single application all of them are a silicone base lubricant so don't worry about which is the best. The application will also determine if the visual inspection and cleaning did the job and if the breaker trips then you have a belt and deck issue.
Jul 18, 2010 | Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Walking belt on image 10.0 tread mill slips, purchased it used, can see where it has rubbed to the left. How to adjust it?
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Feb 25, 2010 | Exercise & Fitness
Exercise & Fitness Logo
185 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
