Question about Perfect Commercial Upright Vacuum Cleaner Belt Part PU-23
Need belt pu-23
Need belt for vacuum part pu-23
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vaccuum.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725351
Generic problem for all Vacuums
Posted by mahammons on Jun 30, 2008
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vacuum.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can think of if that the brushroll may have to be rebuilt and new bearings need to be installed on each end. If unrebuildable, then you need to purchase a new one but most are rebuildable. The other thing is to check the motor pulley to see if that spins freely as well. If you have a problem or other questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
How to change the belt on a Eureka Mighty Mite II.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700499
Posted by Sawpit1 on Jun 23, 2008
How do I change the belt on a Eureka Mighty Mite II.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally the Mighty Mite II does not have a belt unless you have the model with the turbo head and then I believe it is a geared belt and then you can pup the belt from your local vacuum cleaner dealer or the Eureka factory parts dept. there are 2 to 4 screws on the bottom of the turbo head and then I believe the top will come up and then you can get to the belt. The average belt change is every year if it is a geared belt for the best cleaning or if you have a flat belt it is every 4 to 6 months. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Brush roll not working on hoover upright U6455-900
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700283
Posted by archiesmail on Jun 23, 2008
Brush roll not working on Hoover Upright U6455-900
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Upright U6455-900. You may want to check to see if the belt is on or possibly stretched and then replace the belt because the belt does turn the brushroll and if the belt is broken then the brushroll will not turn. 2nd. if the belt is in tact then check the brushroll to see if that spins freely and if it does not then the ends could be bound up with thread and hair and that would need to be cleaned off then place a new belt on because the average belt change is every 4 to 6 months for the best cleaning for your carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Changing belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700198
Changing belt
Posted by Tribbles007 on Jun 23, 2008
Changing belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally there are 2 to 4 screws or clips, levers on the bottom of the vacuum, and then you can remove the bottom plate or top cover and then you can get @ the belt to change it. Unfortunately, I do not know the brand name and model& serial 3 in order to tell you the exact method for the belt change. You can check with your local vacuum cleaner dealer in your area or contact the vacuum factory tech support line. Such as: Example….
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
I need to replace the belt on my vaccum. I lost my manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698951
Posted by 4eversofia on Jun 23, 2008
I need to replace the belt on my vacuum. I lost my manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top.The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
DONT KNOW HOW TO CHANGE MY BELT
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698891
Posted by mommyhop1 on Jun 23, 2008
I LOST MY MANUAL TO SEE HOW TO CHANGE MY BELT. TRYING TO FIND THE USERS MANUAL FOR MY ELECTROLUX 3500 SR
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owner’s manual is to contact the Electrolux factory and either download the owners manual from the website or call the customer service phone # and give them the model and serial # of the machine and they will send you out an owners manual for the product. Or you can contact your local vacuum cleaner dealer in your area and they would assist you in changing your belt. Usually there are screws in the bottom of the vacuum and either the bottom will come off or the top cover will lift off and then you can change the belt. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
I require a new drive belt for my upright vacuum cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698244
Posted by martiy on Jun 23, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Perfect Commercial Upright Vacuum Cleaner Belt Part PU-23 Logo
18 people viewed this question
Top Perfect Vacuums Experts
JoeVacs
Are you a Perfect Vacuum Expert? Answer questions, earn points and help others
